Old 07-22-2010, 08:44 PM
vaed2010 vaed2010 is offline
Mein Auto: BMW 745li
Question Emissions related fault OBDII P0430 & P0491
I'm sure someone has had this issue... I have the check engine soon light on, with the error reading Emissions Related Fault. The OBDII reader came up with codes P0430 Catalyst Efficiency Below Threshold (Bank 2) and P0491 and Secondary Air System (Bank 1). Need help on this one peoples... No real lose in power.
Old 07-22-2010, 11:57 PM
rawdog805 rawdog805 is offline
Mein Auto: 05 645Ci
I also have the P0430 Catalyst Efficiency Below Threshold (Bank 2) error, have not had time to go into the dealership and have them tell me what the price will be to repair.. Dont really care to much to get it fixed as it is only annoying because the check engine light is on.. lol...
2005 645 Ci (Sold)
8000K HID Bulbs + 7W Ebay Halos & Fog Lights + 21" 128 Style Wheels + K&N Air Filter + Replica CSR Front Lip + Triple Resonator Delete with X-Pipe + Aux Input with Bluetooth Dongle +
2002 745 LI (Sold)
2006 X5 (Sold)
Old 07-23-2010, 12:34 AM
7_up's Avatar
7_up 7_up is offline
Mein Auto: 745 Li
It should cut off in a day or too if not go to pep boys and they will clear the code for free.
Old 07-23-2010, 02:27 AM
Mein Auto: 05 645Ci
it usually cuts off after about 300-400 miles of driving, but 2-3 days later it comes back.. Also the couple of Pep boys that I have around me suck as they will not clear any codes for free, which sucks..
2005 645 Ci (Sold)
2002 745 LI (Sold)
2006 X5 (Sold)
Old 07-23-2010, 11:07 AM
Yeah, I got it cleared and it came back within 60 miles. I have till next August to get it fixed, don't mind that - I know nothing last forever and this is a common repair with the 7's. I just want this annoying CEL out. But I do want the root cause of the problem to be repaired as I don't want it popping back up after I dump thousands into a repair.
Old 08-04-2010, 03:04 PM
lex91 lex91 is offline
Mein Auto: 745 Li
Hi, did you ever figure out what the problem was? I had the same error code from Autozone, went to the dealer and they said the secondary air pump and relay needed to be replaced... paid 1015 for that and the SES light came back on after about 100 miles. I'm so frustrated and don't know what else it could be.
Old 08-04-2010, 06:29 PM
7_up's Avatar
Mein Auto: 745 Li
I would check and maybe change the bank 1 sensor and then reset and go from there. (PO430) bank 2
Old 08-05-2010, 07:39 AM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64/5, Maserati GT
i had catalytic converter replaced and it p0430 never came back. and my hose was disconnected behind the motor on my p0491. i just took off firewall partion to free up space, reached back there and reconnected it. voila, no more p0491. if your secondary air pump was bad youd have a code on both sides, p0491 and p0492. so its either your hose or valve on passenger side.
650i sport hud ac schnitzer eibach resognator delete m6 quads akebonos
Old 09-28-2011, 08:57 PM
italiano italiano is offline
Mein Auto: 2007 BMW 745li
Can you explain Faison how you took off the firewall portion to reconnect this hose I have the same code and am trying to figure this out. Any help from anyone would be great. I just have only p0491
Old 10-05-2011, 07:05 PM
cp3854 cp3854 is offline
Mein Auto: 745li
Catalytic Converter
May I ask if you were able to replace the catalytic converter by yourself or had to take it into a shop/dealer? And how much did it cost you? I fixed p0492 but p0430 keeps coming back and I am trying to see if cat can be replaced myself. Thanks,
Old 10-05-2011, 07:14 PM
tiger187's Avatar
tiger187 tiger187 is offline
Mein Auto: 750i
The Pep Boys around here stopped doing it. I bought a code reader on sale for $49.00. It came with a code list and allows me to reset the light. Luckily I have not had to use it (knock on wood).
Old 10-06-2011, 12:03 AM
manny187 manny187 is offline
Mein Auto: 2002 bmw 745i
i had 2 error codes come on p0491 and p0492, the car failed aircare because of the check engine light was on.....took the car to nixon bmw, they said this was a very common problem in the bmw 745i and said to fix the problem it will cost alot of money. They said it was not worth to fix the problem because it has nothing to do with the performance of the car. They said for 500 dollars they have the software that can disable the secondary air flow unit so it does not work no more.
Old 11-05-2011, 10:21 PM
745ion22sCA 745ion22sCA is offline
Mein Auto: 2003 BMW 745i
For the DIY fix to the PO491 and PO492 codes... check out my post here:
http://www.bimmerfest.com/forums/sho...050&highlight=
2003 BMW 745i
Pro Street 1967 Chevy Camaro
Old 11-12-2011, 07:31 PM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 328GT/740LI/750LI
Can some one please send me a link on where I can buy the scanner to clear codes?
13 740LI W/Msport package. Executive Package
DRIVER ASSISTANCE PKG, HUD,
OYSTER; NAPPA LEATHER SEAT TRIM,
Lane departure, blind spot detection,
Collision Mitigation,
Side & Top View Cameras
Aftermarket Rear entertainment
Old 11-12-2011, 07:48 PM
roadfrog's Avatar
roadfrog roadfrog is offline
Mein Auto: 2003 745i
http://www.harborfreight.com/can-obd...ner-98614.html
This is the one I have and it is a well-made product. It actually tells you the code as well as the description of the problem. It also does live feed data and also stores data. It gives pending codes, readiness indicator status, etc. Can't say enough about it.
Old 11-12-2011, 08:01 PM
Rookie2008's Avatar
Thanks Alot!
emissions related fault, p0430, p0491
