Mobile Electronics and Lighting
Car Stereos, Cell Phones, DDEs, HIDs, foglights etc... |
12" Subwoofer and Mono Amp
This is the system i was running in my e39, located @ 92129.
Image Dynamics IDQ-12 Custom 1.6 ft^3 Sealed Box ![]() Box dimentions: Bottom Depth: 10" Top Depth: 5" Width: 32" Hight: 16" Internal Volume: 1.6 cubic feet Driver Properties: Image Dynamics IDQ12-20SVC IMP: 4ohms Re: 3.9 Fs: 19Hz Qes: .30 Qms: 3.50 Qts: .28 Vas: 220l Xmax: 9.5mm Sd: 530 cm^2 Sensitivity: 91.8db Rms Power: 300w Peek Power: 700w ![]() ![]() ![]() ![]() Price: $185 + actual shipping costs Kenwood KAC-8103D Class D Monoblock Amplifier ![]() ![]() RMS Power Output at 4 Ohms (Watts x Channels): 300 x 1 RMS Power at 2 Ohms (Watts x Channels): 500 x 1 Peak Power Output (Watts x Channels): 1000 x 1 2 ohm stable Frequency Response: 5-20 Hz THD at Rated RMS Power: 1% Signal to Noise Ratio: 85 dB Class D Amplifier Low-Pass Crossover Frequency: 50-200 Hz Low-Pass Slope (dB/octave): -24 dB Bass Boost: 0-18 dB Bass Boost Frequency: 40 Hz Infrasonic Filter: 15 Hz, 25 Hz, 18 dB/Octave Preamp Outputs: 1 pair Preamp Inputs: 1 pair Variable Input Sensitivity: 200 mV - 5 V LED Power Indicator: Yes Fan Cooled: Yes Fuse Rating: 40 x 1 Width: 11-11/16 inches Height: 2-1/2 Depth: 12-7/16 Price: $110 + actual shipping costs
Alida: Born: Friday, 9th January 1998 Arktissilber Metallic on Schwarz 528i/5 ![]() Fs: KAC-8103D, Kicker 08ts10l52 |
sub and box
Do you have a ski pass in your e39. I want to purchase the sub and box. I have heard thru the forum you have to have either a ski pass or cut out in the rear deck to actually get the sound from the sub. By any chance do you have either if no how did the sub sound. How much to ship to 30318.
in my car i just knocked out the dsp sub cut outs... they are like two 3" diameter ports.. leme check the shipping and pm you.
bump
All pms replied.
new year bump!
Still for Sale!
The IDQ and box are no longer for sale. The amp is still avaliable.
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
