98 740il loud noise comming from head - Bimmerfest - BMW Forums
Old 07-25-2010, 12:08 PM
JUNEBLOOD JUNEBLOOD is offline
Mein Auto: BROOKLYN
Well it sounds like no oil gouing to the heads
Old 07-25-2010, 03:45 PM
rrtec's Avatar
rrtec rrtec is offline
Bored Worker
Mein Auto: 540i/6 4/99
Post a video..
2001 740il Sport- Needs maintenance.. Parts ordered..
2006 Volvo XC90- Kid Hauler
FC3S LS1/6Speed
1992 BMW K75s Cafe build
Old 07-25-2010, 04:27 PM
balance balance is offline
Mein Auto: 97 740iL
Oil pump bolts coming loose is a common problem on M62 motors. It could be a possibility. Also, I saw on one of your pics that your oil filter housing was loose, so make sure one of the rubber lines isn't kinked.
Old 07-25-2010, 05:27 PM
Mein Auto: 97 740iL
Looking at your post in another thread, you said that you installed a 01 motor in your 96, and you said that you used the harness from the 96. In some cars, the variable valve timing is adjusted by oil pressure to the cam pulleys, by the oil control solenoid. If BMWs use this setup, and you didn't connect the solenoid, then your cam pulley is being starved of oil.
Old 07-30-2010, 11:45 AM
Mein Auto: BROOKLYN
@balance thanks and im getting it together and if the vanos are not hooked up the car will just run and drive in retard mode but its still fast and all but not fast as a working vanos car lol
Old 07-30-2010, 03:47 PM
Mein Auto: 97 740iL
Alright
If the timing is going to be retarded anyways, you could probably save some money at the pump by going to a lower grade gas.
HTML code is Off
