Old 07-26-2010, 01:12 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
AAA is towing my car in 30 minutes (total electrical failure)
AAA is towing my car in 30 minutes (total electrical failure).
Unfolding story:
- E39 wouldn't start this morning for some reason (unknown);
- Charged with a battery charger for 1/2 hour; car started fine;
- No lights on the dash whatsoever; no abnormal running
- Drove 25 miles; enough to charge battery; shut down car;
- Car would not start. Nothing. Got another jump from a passerby;
- With jumpers, car started in seconds; didn't even sound groany;
- No indicator lights; can't tell if battery indicator is green/yellow/black;
- Looks black but you can't get your head inside the trunk to really see;
- Drove car heading home for about 15 miles; But then ...
- Radio started cutting in and out;
- Red battery symbol showed up on dash for the first time;
- TRANS FAILSAFE PROGRAM flashed on the cluster a minute before it died;
- Car died midway in the road; luckily I was able to roll off to the side;
- Got a jump from a passerby; let it sit charging the battery for 5 min;
- Passerby had to go; started driving; red battery light is lit solid;
- E39 didn't get a half mile; stumbled; and then just shut down;
- Pulled over to the side; called a friend; she picked me up;
- Called AAA; they're on the way (will have to go back out to car).
Will research, after they tow me, whether it's:
- Alternator perhaps not charging (but why the red light so late?)
- Battery bad (new BMW battery in 2008); no sign of deterioration
- FSU was replaced in 2008 or 2009 (no signs of erratic A/C blower)
Will need debugging hints. TIA
Old 07-26-2010, 01:53 PM
jarhed1964 jarhed1964 is offline
Mein Auto: '99 528i Sport, '05 530i
Hmm...
My mind says alternator and/or bad battery. I've bought brand new batteries that were dead within four months. It happens on occasion. I'd have it checked to see if it will even hold a charge. At the same time, I'd get that alternator tested.
Old 07-26-2010, 01:59 PM
s140s s140s is offline
Mein Auto: 2001 530i Sport AW
Souds like
1. Internal Alternator Part Failure - Brushes
2. Voltage Regulator
3. Battery
Old 07-26-2010, 02:11 PM
mmm635's Avatar
mmm635 mmm635 is offline
Mein Auto: '02 525i Sp/5, 95 FJ80 LC
Blue...looks like you need a new alternator from that description.
Old 07-26-2010, 02:34 PM
E39 Paul E39 Paul is offline
Mein Auto: e39 530i
+1 on alternator. Had exact same symptoms years ago on Renault Clio Williams I have. Was stuck 30ish miles from home. Mate turned up and towed to his garage. Replaced alternator and battery!!!
Old 07-26-2010, 03:00 PM
paferri's Avatar
paferri paferri is offline
Mein Auto: '98 Alpine White E39 528i
classic alternator symptoms....agreed
1998 528iA MFD Date: 6/1998
Lets go Islanders!!!!
Old 07-26-2010, 03:43 PM
bluebee's Avatar
Just got E39 off the flatbed. Was interesting to see him tow it.
He towed from the front hook that I pulled out of the trunk kit (wish I had a reflector in that kit given the danger in the roadway when it happened).
1. He pushed with his finger at the arrow in the front bumper
2. Off popped the toe-hook hole cover
3. He asked me for the tow hook which I pulled out of the trunk kit
4. He screwed it in hand tight - then with a pry bar really tightly
(He said when they pop out, people get killed.)
5. He hooked his winch up to that tow hook
6. He put the keys in the ignition and steered it to the flatbed
7. Twice he had to stop pulling to re-steer into the flatbed
8. Once flat, he strapped the front wheels
9. And he chain-hooked the rear suspension
10. He kept the tow hook engaged all the time
Once it was flat, he strapped the front wheels and chain-hooked the rear suspension from the aluminum "hinged beam" parts. When I mentioned to him not to "bend" anything, he said a lot of drivers bend this part by putting too much tension on it. He said the trick is to keep the hook close the the center and as far from the wheel as possible.
Anyway, as soon as I submit this impromptu "DIY towing" post, I'll be digging for alternator DIYs.
ID:	239778   Click image for larger version
ID:	239779   Click image for larger version
ID:	239780   Click image for larger version
ID:	239781   Click image for larger version
Old 07-26-2010, 03:44 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Would CN90's alternator rebuild be a good preventative?
Old 07-26-2010, 04:19 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport, Scuderia
+3 on the alternator...classic symptoms described. While it might be okay to hook to the suspension, I have always seen the tow truck operator to leave the front winch attached as shown, but to only secure the car to the flat bed with nylon straps through each wheel. I suppose hooks on the suspension would be the only choice the straps cannot go through the wheels...
540 M-Sport package (Canadian market), factory Bluetooth phone kit, factory M-Audio 10" dual voice coil subs, Homelink, M5 rear stabilizer bar, H&R 15mm spacers, Bilstein B14 PSS coil overs, Stop Tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, Strong Strut front upper stress bar, BMP strut tower reinforcement kit, USA Spec Ipod/Iphone integration.
Old 07-26-2010, 04:51 PM
bluebee's Avatar
I don't disagree it's likely either the alternator or the battery.
What I need first, is a good DIY for testing what the bad component is.
Testing a battery is reasonably straightforward but I have little clue how to test an alternator.
MY GUESS HOW TO TEST A BATTERY:
- Note dash indicators (red battery light now; but not before)
- Note the date (this one is just a couple of years old)
- Note the indicator lamp (hard to see, but looks pretty black to me)
- Note the voltage after charging (is taking 5 amps on the charger now)
- Note the voltage drop with lights on as a load (need to do after it charges)
- Note each cell's specific gravity (need to find my almost-never used hygrometer)
- Note whether it takes a charge (it seems to take a charge so far)
- What else do we test to see if it's the battery?
MY GUESS HOW TO TEST AN ALTERNATOR:
- Note the brand & model of alternator (need to figure that out)
- Note dashboard indications (red battery light only now; not before)
- With charged battery, note voltage before & after starting (I assume the voltage will go UP after starting the car due to alternator output)
- Put an ammeter on the output from the alternator (need to find my ammeter hookup and need to find WHERE the wire comes out of alternator)
- Anything else to test alternator?
To find how to test an alternator, I first went to the best-links and searched for "alternator", finding only these two DIYs:
- cn90 alternator rebuild DIY
- Massive cn90 DIY Oil Line ---> Vanos, CCV, ICV and Alternator Air Duct
Using the search button, I am overwhelmed by over 1,000 results for "alternator", so I need to narrow it down to the threads which show how to TEST the alternator!
- This post says to identify if it's Bosch or Valeo first (with a mirror)
- If it's the battery, QSilver7 says consider the Duralast 49DL (or 94R?)
- If it's the alternator, QSilver7 says to check belts, pulleys & tensioners
- cn90 lists alternator removal instructions in step #6 of this post
- cn90 lists rebuild alternator parts here ... (and the Greely source here, 8am - 4pm MST, M-F)
- This post says alternator should be putting out 14.5 volts
- This post says to check the positive cable mechanical connection
- Here, 540M-sport recommends this $100 alternator tester
- Here they say autozone can test the alternator off the car
- Fast-Bob says the regulator is inside the alternator; cleaning cables sometimes helps
- A DMM test of the alternator is proposed in this post
- E46 Alternator Removal DIY
- Edjack suggests a test for alternator not putting out enough juice
- cn90 suggests what to look out for in a rebuilt alternator
- cn90 suggests a test for bad cabling
- doru find of range rover bosch alternator rebuild
Still haven't seen a comprehensive step-by-step DIY for testing the alternator (but will keep searching).
BTW, I put the charger on it and it immediately took almost 6 amps and then slowly started to take fewer amps. It's still charging as we type.
Old 07-26-2010, 04:57 PM
Fooljam's Avatar
Fooljam Fooljam is offline
Mein Auto: Unknown error...
Another moronic tower...Do not tow a bimmer through suspension parts...
There is one hole on the front, one on the rear.
Once the car is lifted, secure through the wheels, not the suspension.
Make sure once you have the car back everything is fine with the suspension.
Old 07-26-2010, 05:03 PM
bluebee's Avatar
He put straps thru the front wheels but not the rear wheels (which are the same style). Dunno exactly why.
I'm gonna let the battery charge for a few hours, and then test the voltage this way (does this look like the right approach)?
A quick survey of about two dozen "alternator" articles nets me the following DIY test for the alternator (so far):
0. With a mirror, identify brand and type of alternator (what am I looking for)?
1. Test voltage across battery with car off (look for around 12-14 volts)
2. Test voltage across engine terminals with car off (should be the same)
3. Turn headlights on for at least one minute & then turn them off; test voltage at engine or battery (shouldn't drop too much ... how much is too much?)
4. Start car ... test voltage across engine terminals (should be higher than 14 volts if the alternator is working)
5. Check current going INTO the battery positive terminal (should be ?? amps)
6. Check current coming out of back of alternator (should be ?? amps)
7. If the alternator isn't putting out, then you need to (somehow) check the belts and or tensioners for tension (I'm not sure how). At least I can check if the alternator is "turning" ... is that enough?
Old 07-26-2010, 05:05 PM
87vert's Avatar
87vert 87vert is offline
Mein Auto: '02 BMW 525i
I am thinking the alternator also.
Not really DIY but PepBoys can usually test alternators if you pull it and bring it in. I used to do them all the time when I worked there.
'02 525i - Titanium Gray
Blitz Safe AUX Audio Connector
Old 07-26-2010, 05:10 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
My two cents: TRANS FAILSAFE often is triggered by a bad ignition switch.
BMWCCA#401441
Old 07-26-2010, 05:24 PM
bluebee's Avatar
(I am just now starting to flip through the Bentleys to see how to test the alternator while the battery is charging).
While it's charging, may I ask if it matters whether I charge the battery from the engine compartment or from the trunk?
BTW, it's taking 4 amps, even an hour after I hooked it up!
Old 07-26-2010, 05:47 PM
QSilver7's Avatar
QSilver7 QSilver7 is offline
No mention of TEST 9?
A quick check BMW owners can do is TEST 9. If you've unlocked your instrument cluster...with the ignition in position 1 or 2...it will show the BATTERY's voltage. Check this BEFORE you start or charge the battery because you want to check it BEFORE it receives a "surface charge"...which can give you an untrue reading of the battery's health.
If you run TEST 9 with the engine running...you will get an idea of the car's charging system voltage. With the engine running, you should have voltage numbers between 12.8 - 14+ volts....this is required since you have a 12 volt battery...in order to "replenish" the battery, it needs to receive more than it gives.
Blue, I don't remember if you have the high or the low instrument cluster...so you'll have to go to my CarDomain site and scroll down to which ever one you have to see the instruction on how to UNLOCK the instrument cluster's OBC to access the 21 TESTs: http://www.cardomain.com/ride/3134093/6
Low Cluster (do TEST #19 to UNLOCK the cluster): (a bit more complicated since there's only 1 button on the instrument cluster)
High Cluster:
Q {BMW CCA Member #191509}
(SOLD)
Old 07-26-2010, 05:59 PM
xraye39 xraye39 is offline
Mein Auto: 530i
Unfolding story:
Bluebee,
This is where you should have stopped and saved yourself a bunch of aggravation, just like a human your car was giving you symptoms of an underlying problem.
I would have whipped out my multimeter and checked the charge of the battery and then once I jumped it I would have checked the output of the alternator.
If you do not possess a multimeter you can buy a pretty simple cheap one a Home Depot, Radio Shack etc.
You could also utilized the built in voltage meter by unlocking your cluster.
Just some food for thought
2003 530iA Sport - Titangrau Metallic/Schwarz Montana
Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland
NAV MKIV | PP | CWP | Xenons | Style 42s | Rear Shades | OEM ULF Bluetooth | Euro Armrest | Beisan Vanos Seals |
2003 530i/5Spd Sport - Titanium Silber/Schwarz Montana
| PP | Xenons | Style 42s | OEM TCU Bluetooth | Euro Armrest | Beisan Vanos Seals |
2001 525iA - Anthracite Metalic / Grau Montana
Sold but in the "family"
Old 07-26-2010, 06:16 PM
TemporarySanity's Avatar
TemporarySanity TemporarySanity is offline
Mein Auto: 02 530, 02 540, 07 525
I had the same symptoms when my alternator went south.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot.
Old 07-26-2010, 06:35 PM
borderchris's Avatar
borderchris borderchris is offline
Was ist los? Der Hund!
Mein Auto: 335i E92
Based on the symptoms, I'm going to have to disagree with you on this one. The failsafe mode is simply a sign of the low system voltage in this case. The transmission computer uses quite a bit of juice to do it's thinking, and when you cut the power down significantly, you pay for it in limited function.
Happened to me on the '01 530iA, and the first thing to go was the shifting. I though I had a blown transmission- turned out later that I needed a new alternator... Another reason I love my 5 speed, now!
2007 E92 335i . Space Grey . Premium . Sport
2006 E85 M Roadster . Alpine White . 6MT
2006 E60 550i . Sapphire Black . A5 . Sport . Premium
2003 E39 530i . Titanium Grey . 5MT . Sport . Premium
1989 E34 535i . Black . A4 . Premium . RIP
1981 E28 530 . Grey . A4 . German Specs . RIP '94 in USAREUR
1977 E21 320 . Light Blue . 4MT . German Specs . RIP '92 in USAREUR
Old 07-26-2010, 07:08 PM
Fudman's Avatar
Fudman Fudman is offline
Bluebee:
If you confirm it is indeed your alternator, here are some DIYs for alternator replacement. Sorry, don't have one for the 525. But these should be close. Good luck andplease post what the cause of your problem actually is when you know. Thanx.
This is for a 540:
http://forums.bimmerforums.com/forum....php?t=1463422
This is for a 740i:
http://www.bimmerboard.com/forums/posts/355405
This si for a 528i:
http://forums.bimmerforums.com/forum...alternator+DIY
Follow cn90s steps 1-6 here:
http://wwww.bimmerfest.com/forums/sh....php?p=4719959
An abbreviated cn90 DIY for alternator DIY:
http://www.bimmerfest.com/forums/sho...alternator+diy
Old 07-26-2010, 07:29 PM
cn90 cn90 is offline
bluebee,
PM edjack (he is in San Jose too) to see if he can help you.
Old 07-26-2010, 07:46 PM
doru's Avatar
doru doru is offline
Mein Auto: 2003 530iA
And Donna, what Qsilver said: test #9. Very easy to do, and gives you tons of info.
FYI, when running, my alt shows about 13,7V and my car is a 2003, so quite close to yours in terms of manufacturing. Not sure about the alternator brand.
Might need to swap those brushes out as mentioned above. but do test #9 first.
If you swap the brushes, test the bearings too.
Cheers
Old 07-26-2010, 09:24 PM
It was not towed by the suspension, it was only secured to the flat bed via the suspension bits. Still not ideal. At the minimum, I would have used nylon straps rather than metal hooks to the arms.
Old 07-26-2010, 09:27 PM
+1, same happened to me when my alternator failed.
Old 07-26-2010, 09:28 PM
Safest to charge from the engine compartment, less chance of igniting battery gases. That is why BMW recommends that way.
