E36 (1991 - 1999)
Old 07-28-2010, 10:52 AM
redhead3391 redhead3391 is offline
Mein Auto: 1996 318i Convertible
Overheating
I have a 1996 318i convertible, it keeps overheating at low speeds but runs fine in normal driving conditions. Where do I start looking in order to fix this problem?
Old 07-28-2010, 11:07 AM
Hellawut??
Mein Auto: who knows?
air in your cooling system
Search hwo to bleed it
And for fcuking sake these overheating threads need to end
-Franklyn
Old 07-28-2010, 11:11 AM
Mr Gusta's Avatar
Mr Gusta Mr Gusta is offline
Fireballs inc.
Send a message via AIM to Mr Gusta
Mein Auto: big turbo hellrot sedan
i might make one
op it could also be your waterpump...
when is the last time it was replaced?
Turbo lag is just a headstart because the chase is more exciting than the win - Abraham Lincoln
Old 07-28-2010, 11:12 AM
TnT817's Avatar
TnT817 TnT817 is offline
Mein Auto: 1993 325i 4dr
I think we all should make one just to make franklyn mad
Old 07-28-2010, 11:17 AM
Theo podges Theo podges is offline
Mein Auto: '96 328i, '98 318is.
I will start with the fan. The reason I think so is because there isn't enough air coming through the radiator when you are driving slow, the fan is suppose to make up for the airflow and it doesn't. Hope this will help.
Old 07-28-2010, 11:21 AM
BimmerBling's Avatar
BimmerBling BimmerBling is offline
College Kid
Mein Auto: 93 318is
^ same thing i was about to say. +1 on the fan.
As soon as the overheating ends, the threads will too. Which is never.
My name is///Mark
Old 07-28-2010, 02:03 PM
Chris S Chris S is offline
Mein Auto: 1997 323i
+1 fan
Tinting, Phillips Vision Bulbs, NGK standard Spark Plugs, Yokohama S-Drive Tyres
Old 07-28-2010, 02:07 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
Fire breathing dragons...
Instagram | @randytheus
Old 07-28-2010, 02:13 PM
Thank you for the suggestions...... cause I was thinking thermostat?
Old 07-28-2010, 03:14 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
no, not a typical stat issue. more along the lines of a fan/fan clutch issue.
df
"fire breathing dragons".......................yeah, right
Old 07-29-2010, 05:58 AM
injunmort injunmort is offline
Mein Auto: 1990 525, 1991 535
you guys put too much emphasis on fan/fanclutch. the fan does very little in the way of cooling at slow speeds and actually hinders air flow at driving speeds. if it is turning it is doing what it is supposed to. bleed the system and check for leaks and good coolant flow. leave the fan alone.
Old 07-29-2010, 07:30 AM
e36mike's Avatar
e36mike e36mike is offline
Mein Auto: e30 e36 e368
not true.
when the car is hot roll up a newspaper and stick it in the fan. if you can stop it then you probably got a problem with fan clutch/fan. usually you'll have a overheating mostly when stopped or going very slow like in traffic. we just did my friends on his m3, with a newpaper we could stop his fan like nothing, we come over to my car and the fan would nearly eat the newspaper.
if you overheat at low speeds it could be your fan clutch/fan or your system needs to be properly flushed and filled.
Originally Posted by tony5522 View Post
all these haters wish they could afford lexani rims..they look way better then bbs rims
Old 07-29-2010, 09:47 AM
see what i said about the fan turning. it is to provide a small displacement of air thru the radiator where there would normally only be covection, eg a standstill. if the fan is turning it is doing its job. what else did you replace on this m3 that stopped the low speed overheat, because if it took a rolled up newspaper to stop the fan, the fan was not the problem.
Old 07-30-2010, 06:59 PM
diego652 diego652 is offline
Diego
Mein Auto: 93 BMW 325i
same thing used to happen with my car at low or standstill it got hot, so i checked the auxiliary fan turns out a fuse was blown i think its number 32. anyway once i replaced the fuse the thing is back to normal.
Old 07-30-2010, 07:10 PM
College Kid
Mein Auto: 93 318is
Your logic makes no sense.
If a fan can be stopped by a newspaper its not working correctly, meaning it needs to be fixed. Period.
My name is///Mark
Old 07-30-2010, 09:44 PM
sethum sethum is offline
9.04 1/8 mile 1.79 60 ft
Mein Auto: e36 328is
i can stop my fan with a rag and my hand and i dont overheat.
and its 100 degree weather right now.
bmw by sethum13, on Flickr
Old 07-30-2010, 10:09 PM
College Kid
Mein Auto: 93 318is
Just because you dont overheat, doesnt mean the fan is working properly.
My name is///Mark
Old 07-31-2010, 01:41 AM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Misinformation.
Check your facts. If you don't know them, please take the few seconds to mention that your post is conjecture or speculation.
Originally Posted by e36mike View Post
not true.
Truth.
Wow. Just wow.
Truth.
Then you are simply lucky. Your fan isn't working. Period.
Thank you Mark. Someone here has a clue what they are talking about.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 07-31-2010, 09:05 AM
PhilipWOT's Avatar
PhilipWOT PhilipWOT is offline
Turn Burglar
Location: Atl: Come for the pollution, stay for the traffic
Mein Auto: Red Assless Chaps
There is a small unicorn in your engine jumping around poking holes in things and sh*tting in filters. That will be $6000.
Old 07-31-2010, 12:40 PM
College Kid
Mein Auto: 93 318is
Originally Posted by jonesin View Post
Misinformation.
Truth.
Wow. Just wow.
Truth.
Thanks for backing me up Ed. I really appreciate it.
My name is///Mark
Old 07-31-2010, 12:51 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
Misinformation.
Truth.
Wow. Just wow.
Truth.
+2
Here are the basics:
Overheating at slow speed only = not enough airflow through the radiator, which = fan clutch or aux fan problem.
Overheating at 20+ mph = bad waterpump or blockage in cooling system (possible bad thermostat, or other obstruction).
Sporadic overheating = air trapped in the cooling system.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 07-31-2010, 06:31 PM
College Kid
Mein Auto: 93 318is
Originally Posted by wag-zhp View Post
+2
Overheating at slow speed or idle = not enough airflow through the radiator, which = fan clutch or aux fan problem.
Fixed?.
My name is///Mark
Old 07-31-2010, 06:50 PM
Fixed?.
not if it's still overheating......oh, sorry, you, uh,...meant the post.....
df
Old 07-31-2010, 07:48 PM
wag-zhp's Avatar
Fixed?.
U. S. M. C.
Semper Fidelis
Old 07-31-2010, 11:18 PM
College Kid
Mein Auto: 93 318is
df
My name is///Mark
:3
