#76
Here is the revised list. I changed it to 1 bleeder screw and added the timing chain tensioner. I also added the critical column. When we are done we'll figure out to share the file.
#77
Absolutely beautiful!
We just added the "expansion tank pressure cap" to the critical list (based on the other thread). And, Quick99Si has done a great job making BMW factory & dealer tools available via his FTP site so maybe he can host this spreadsheet? - Making sense of ADS, EDIABAS, INPA, NCS, NFS, GT1/DIS, Progman, ISIS, WinKPT, Carsoft |
#78
Based on cn90's recommendation today in this thread:
- How not to change your oil in your E39 (stripped drain plug) Quote:
How does this look as a recommended parts list for changing your oil?
Note: At the same time you change your oil, some recommend you suction out about 8 ounces (250 ml) of the power steering fluid and replace with Dexron III (realistically Dexron VI) ATF: - Recommendation to replace power steering fluid at every oil change & periodically clean the PSF filter (1) So, another related parts list could be:
NOTE: Here is the alternative 'sock mod' in lieu of replacing the power steering fluid reservoir o-ring: Last edited by bluebee; 10-05-2011 at 09:31 AM. |
#79
A nice cooling system overhaul parts list was posted today:
> E39 (1997 - 2003) > Cooling system! be safe than sorry? Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
#80
Thanks for all who contributed to this thread, especially you bluebee. I've got a small coolant leak somewhere and I suspect the culprit is the water pump, so having all the information here is a God send.
#81
This is the list of recommended waterpumps to buy:
- What brand of waterpump to buy (1) I just ran into this parts list from this thread: Quote:
#82
There was a clarification comment on this cooling system overhaul parts list over here today:
#83
my coolant overhaul parts
So I am amassing my parts for the coolant overhaul from different sources and i have a couple of questions before I make my last order:
-From the attached image, how critical is it to change the three marked hoses? Are those known to wear out and leak to at around the same time as everything else? -Does the nissin radiator come with a drain plug and are there any fitment issues different from OEM. Is it better than behr? Thank you. |
#84
My understanding is that most people do not change them - but it's probably a good idea to replace any and all rubber at the age of our vehicles.
But I would base any deeper assessment on a visual check and the current prices. Quote:
- Pictorial look at typical E39 cooling system failure modes (1) IIRC, mine did. Getting the Behr out of the vehicle isn't all that difficult: - Removal instructions for the alternator & drive belt system of a 2002 525i - Removal instructions for the fan shroud of a 2002 525i - Tools necessary for a cooling system overhaul etc. But, on the automatic I6, getting the Nissens/Behr back in is the hardest part: - One user's cooling system overhaul: How to get the radiator back on (1) Methinks they all stink. Personally, I don't wish to reward Behr for making garbage - so I bought Nissens garbage instead. Here you see what the Behr looks like inside: - Behr radiator and Behr expansion (aka surge) tank autopsy (1) (2)
#85
For the crosslinked record, this series of common questions was asked today:
#86
While doing suspension work, I discovered what the big boom was from the week prior. Exploded fan. I had come to stop of driving several hours, floored car hard and it sounds like my rear axle fell off and/or a huge back fire, then what sounded like something fell off of the car. My son and I looked in rear view--nothing. We continued on our way with no isssues. Week later after many miles driven and while doing an unrelated overhaul, I noticed my fan was gone! :-) Car ran fine with no overheating as well. Since replacing it, I notice the needle is ever so slightly more to left of high noon needle mark. I went with Myle clutch and generic fan coolxpert.
#87
Hi Fudman.
No biggie, I'm used to being bummed out. lol. I do plan on completing the cooling overhaul this summer from water pump, thermostat, hoses, etc. Maybe I'll just go and replace fan/clutch--again. :-) it's only money, right. :-) worst/best case, I ride the clutch/fan out till next summer and replace them. at least I'll be a guinea pig for longevity of these parts. I had read some on the behr clutch, but thought Myle was a very good brand. |
#89
For the record, there is a good thread on locating all the cooling system hoses here today:
-> E39 (1997 - 2003) > Want to replace cooling system heater hoses.
#90
First of all thank you to Bluebee and all the others who have contributed to a great thread. I have some questions about the auxiliary water pump.
ID & Part #
Replacement? Unless I missed it in this thread no one really discussed whether this part should be replaced during a cooling overhaul. Any thoughts/input on the expected life of this part? Also if I should be posting this question in a different thread please let me know I don't want to clutter up a great thread with a question that should go someplace else.
E39 2003 530i: SP, CWP, PP, Manual, Sunshades, Split folding rear seats, 17" Style 42s E28 1987 535is: Manual, Bilstein HDs, 16" Style 5v2 (from e38)[Sold] Last edited by Solo12; 06-07-2013 at 04:21 PM. |
#91
Yes. In reality, it's mounted vertically, on the drivers side of the radiator, on the inside edge, almost at the bottom, so the easiest access is from below.
Unfortunately I don't know what models have it and what ones don't. But if you type in your VIN to http://realoem.com, it should tell you if you have it. I checked my Realoem vin and it's found in Heater and Air Conditioning Water pump, valve, hoses Hoses f pump and valve/autom.air cond. You can google for my part number to get an idea of prices 64118381989. http://www.fcpeuro.com/products/bmw-...Fck-MgodH0QARQ http://www.eeuroparts.com/Parts/2968...Fc9DMgodIBMA9w I don't know anybody who has replaced it and it's not a normally replaced part in a cooling system overhaul. Last edited by shaftdrive; 06-09-2013 at 10:04 AM. |
#92
I don't know if anyone has suggested this yet, but for the DISA, you can get square-cross-section o-rings of almost any material you like.
For example https://www.mfpseals.com/catalog/cat...trong-nitrile- And, of course, you can get round-cross-section o-rings at lots of places too, for the VANOS or for other parts 1. (easy to use oring warehouse calculator) 2. the o-ring store 3. mfp seals 4. orings usa What we need is a list of the "trade sizes" for each of the replacement orings, and the material. 1. http://www.allorings.com/size_cross_...nce_framed.htm 2. http://www.marcorubber.com/sizingchart.htm 3. http://www.broadleyjames.com/o-rings-size-chart.html Last edited by Crutzy; 06-09-2013 at 09:17 PM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
