Old 07-31-2010, 05:09 PM
COLO740i COLO740i is offline
Mein Auto: 95 740i
Exclamation Radiator hose question
what would make my radator hose keep popping off ?
Old 07-31-2010, 08:33 PM
balance balance is offline
Mein Auto: 97 740iL
Maybe a bad clamp or eccessive pressure.
Old 07-31-2010, 09:52 PM
Mein Auto: 95 740i
y would it have extra pressure
Old 08-01-2010, 09:56 AM
Mein Auto: 97 740iL
Head gasket could be leaking exhaust gas into coolant, but first change the clamp as the originals are trash, and a bad clamp is alot more likely. It is the upper hose right?
Old 08-01-2010, 05:03 PM
Mein Auto: 95 740i
i found it it was a radator
Old 08-04-2010, 06:59 PM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
Don't know what year your E38 is, but if it has the quick connect ends then this is a common problem of the hose coming off the plastic ends. It was in my case. I just solved the problem by changing the hoses. If they haven't ever been changed, change them. And be ready for other cooling system components to fail shortly after if they are old.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
HTML code is Off
