Old 01-30-2012, 12:19 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
If I correctly read this thread posted today, the OP broke the radiator nipple and was successful in making a temporary expoxy repair until new parts arrived:
- E39 (1997 - 2003) > Notes from my cooling system overhaul
Originally Posted by cwpo1 View Post
2. When removing the fan shroud be very careful to pry upward, not forward. When I removed mine I pried it forward and it broke the vent spout on the top right hand side of the radiator. This was an issue because I initially was changing out the water pump and the belts. So I was forced to epoxy it back together until the radiator and hoses arrived. This is a very temporary fix as it could not gain a total seal and the antifreeze degrades the epoxy over time. It lasted two weeks, just long enough to get the radiatior and hoses in.
Old 01-12-2013, 05:13 PM
SharkD SharkD is offline
SpecE30 #59
Mein Auto: 2003 540i/6 • 1987 325is
Originally Posted by bluebee View Post
- Another lesson I learned, the hard way, is that simply pressing out on the two tabs locking the nipple in place breaks off these two tabs quite easily. The problem with that is that these tabs are part of the radiator, not part of the nipple. So, once you break these two tabs, you're ruined the radiator.
The O-ring on my 3-year-old nipple failed (Behr radiator with a test date of 3/6/2010).
Desipite using two jeweler's screwdrivers to open the tabs and lifting the nipple with a third, the two alignment tabs broke.
Since the tabs don't serve to retain the nipple, only keep it straight, is the radiator really ruined, or is it still safe to run?
(I tried the 9mm socket trick, but couldn't reach the prongs, possibly because 2 were broken when I did get the nipple out.)
Old 01-12-2013, 07:20 PM
cn90 cn90 is offline
Don't worry about those radiator tabs.
Once the nipple is in, the nipple's tabs (inside the rad) will keep the nipple in place.
Plus, when the Fan Shroud is down and the rivet (plastic clip) is attached, the Fan Shroud keeps the nipple downward and it has no chance of coming out.
Just grease the O-ring a tiny bit to slide it in.
This is a photo from my car (taken from another DIY) to show you the rivet on the Fan Shroud:
Old 02-05-2013, 10:09 PM
613fatboy 613fatboy is offline
Mein Auto: 2001 BMW 530i
How to remove rad nipple in one piece :dunno::mad:
Hi,
Interesting problem...here's what I make of the "10 mm socket" solution;
1. Remove upper rad hose.
2. Get a 10 mm socket and tie a string through it so you don't drop the socket inside the rad. Tie the other end of the string to something big.
3. Somehow, you need to manouver the socket inside the hole where the upper rad hose used to be. You want to fit the socket over the 3 "fingers" of the nipple so that when you apply upwards pressure on the socket (toward the nipple), the 3 "fingers" get squeezed in and the entire nipple should just pop right out!
4. Do the happy dance.
NOTE: Looking at your new spare rad nipple, it's obvious that the nipple was meant to stay put unless those 3 "fingers" are somehow compressed, and that is where the 10 mm socket comes in. Practice this with your new spare rad nipple before you attempt it on the actual rad.
Old 02-05-2013, 10:11 PM
Hi,
Old 03-04-2013, 03:17 PM
bluebee's Avatar
I received this PM today, which shows even a broken nipple will seal (perhaps due to the o-ring in the midline of the nipple):
...whilst removing the radiator shroud, having seen your extensive documentation about the radiator nipple, I very carefully eased it out of the hole with two small screwdrivers - I'm sure it offered almost no resistance and came straight up. When it was out, however, I found that two of the three legs had been broken off. I know someone else had worked here previously, in fact, the radiator was not completely seated and didn't have the rivet on one side.
My question is: Is it possible for the cooling system to have operated with the nipple having only one leg? Does it seat well enough with the o-ring? Or would pressure in the system surely have popped it out, thus being evidence that I broke it?
ID:	364772   Click image for larger version
ID:	364773   Click image for larger version
Old 03-21-2013, 10:19 AM
mikeson mikeson is offline
Mein Auto: 99 323i, 2002 525i
I just replace mine yesterday.
Those 2 tabs are just guide for the nipple in right position and it doesn't hold it. So I guess, even we brake those 2 tabs, it is ok.
And I didn't even clear those 2 tabs when I remove the nipple. just left it up with 2 screw drivers and it pop up and came out one piece.
Anyway, thank you for those who put picture as DIY and it helps me a lot.
Old 03-21-2013, 05:00 PM
Quantumlogic Quantumlogic is offline
Mein Auto: 2003 BMW 530i Auto
Thumbs up
while replacing radiator, the nipple came off as if it was just there. no effort realized that it was actually broken. since the coolant was already out a little pry up top and a second pry with a small screwdriver on the radiator drain location caused broken tab to fall out. I was replacing radiator any ways so didn't matter, but the 9mm socket trick is ingenious.
Old 07-25-2013, 12:03 PM
bluebee's Avatar
For the record, this was posted today, with nice pictures:
> E39 (1997 - 2003) > Radiator leak?
Old 07-25-2013, 12:18 PM
hh3uunp's Avatar
hh3uunp hh3uunp is offline
Ball Don't lie
Mein Auto: 2001 Dinan m5
I dremeled the top off then I took a screw driver and punched it into the tank then it fell out the drain pipe.
If first you don't succeed you must try again, and then again
Mods
Dinan S1, Drilled slotted rotors, Akembo Pads, 19 in MPars,Zoinsville Super duty kit,
Resident Grammar and Spelling expert
Old 07-25-2013, 07:47 PM
bluebee's Avatar
That works!
But, the goal is figuring out how to remove the nipple without destroying it.
Old 07-25-2013, 08:10 PM
hh3uunp's Avatar
Ball Don't lie
Why not just replace it? It was like $10 for it.
Mods
Old 10-31-2013, 06:23 AM
bluebee's Avatar
You're missing the whole point. Re-read the first post for the reasons.
Anyway, today this similar thread came up, and it was nice to see that the advice here and elsewhere helped....
> E39 (1997 - 2003) > vent house fitting elbow removal
Originally Posted by onebadbmw View Post
does this piece snap out of place or is there a trick to get it out.
http://www.eaceuroparts.com/parts/pa...00%20419%20132
thanks! another successful diy
File Type: pdf radiator_nipple_replacement_procedure_diy.pdf (574.1 KB, 607 views)
Old 10-31-2013, 06:52 AM
dnbigdog dnbigdog is offline
Mein Auto: 5281
I had to perform this job last week due to a compressed o-ring that was allowing a leak. Thanks to the forum it was easy, just place a screw driver or small pry bar under the horizontal portion of the nipple and pry upward. It popped right out, thankfully intact and changing the new one was simple.
Old 10-31-2013, 08:15 AM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
you got lucky
my bmw indy replaced it, old one came out but one of the legs remained. I doubt it will harm anything as it it too large to clog the radiator passages.
Old 01-01-2014, 02:38 PM
LarryDibat LarryDibat is offline
Mein Auto: 540iT
Cool New Way to Remove the Radiator Nipple - Easy
Received the new nipple from Pelican Parts, stated with a cold car.
Loosen the radiator shroud and moved it towards engine.
Used a heat gun to warm up the radiator and old nipple, once the plastic was a little warmer than I wanted to touch I put a flat screwdriver into the space between the nipple and the radiator from the driver’s side, pressed/twisted slightly. Up it popped!!
Loosened the clamp, pulled out the nipple, put the new one on and snapped it into place.
15 minute repair, no more leak and did it a couple of more times to my buddies cars.
Heat gun, not blow dryer…
Old 05-19-2014, 11:56 AM
bluebee's Avatar
I've never really understood WHAT this so-called "overflow" hose really does, but, the question came up today in another thread, which I'll reference here:
> E39 (1997 - 2003) > coolant seepage, what is this piece?
Originally Posted by Jim K. View Post
Hello All. My 163k, 1997 528i had the top radiator hose suddenly come loose, with predictable needle quickly pegged into red. Got off the road, let it cool down completely, reattached the hose (did not see any plastic piece mentioned by some for 540i, don't know if that applies to 528i?), moved the hose clamp in closer to the radiator, as you can tell in the photo (so it fit in two groves), refilled, bled, etc. Seems okay in that held steady temperature the 4 miles it took me to get home. My question is the small seepage i am getting out of the plastic piece on top of the radiator (rounded piece in picture and can see coolant seep). It has a couple slits in the sides and coolant oozes out once the engine has some temperature. Is this by design as in some sort of relief valve? In other words, is this normal? Would appreciate any info.
thanks,
Jim
See also:
- BMW E39 cooling system autopsy (1) & how not to bleed your cooling system (1)
Old 08-06-2014, 07:31 PM
bluebee's Avatar
For cross reference, there was yet another nipple thread today ...
- Real OEM does NOT have a picture of the part I'm looking for.
Old 08-07-2014, 08:48 AM
bluebee's Avatar
For cross reference, another nipple thread came up today ...
> E39 (1997 - 2003) > Topping off coolant...
Originally Posted by Tommylaw9 View Post
looks like its just the nipple failing. what do you think?
nipple came out like butter. all 3 legs intact. problem is, I can't see any obvious signs of failure. here are pictures post-op. what do you think?
NOTE: I seem to remember the replacement nipple being of a different size than the OEM Behr and/or Nissens nipple, so, that, in and of itself, might be the reason this OPs nipple came out like butter.
Old 12-06-2014, 03:02 PM
bluebee's Avatar
The question came up again today ...
> E39 (1997 - 2003) > Radiator Vent L Nipple
Originally Posted by gchand View Post
Has anyone successfully removed this from the top left of radiator without it snapping and leaving its internal section in the radiator?
Originally Posted by Dking078 View Post
Yup, I did it a few weeks ago. I knew the plastic shaft was going to break somehow, so i removed the upper radiator hose and put a semi rolled up piece of paper to catch any debris. Aside from dropping one tiny piece of the securing clip (prior to inserting paper catch), it was a perfect job... just a bit of lost coolant. So far no leaks what-so-ever!
Prying it up as bluebee mentions is a good start and if it snaps i would use the paper catch and just push the internally stuck part down.
Others mention the 9mm socket on string method, but there was no way on this Earth i could align that with my big fingers XD
Dealer charged about $5 for the vent tube.
Old 03-17-2015, 07:15 PM
dannyman939 dannyman939 is offline
Mein Auto: bmw 528i
has anyone tried tweezers to spread the plastic "feet" apart without breaking the tabs on the radiator housing?
Old 03-17-2015, 07:39 PM
Mein Auto: bmw 528i
it seems that you can push it to the base of the outside housing and if the inner piece is broken, it will release the top part, if the piece is not broken, you can push it further in and it will release the entire tab.
Old 06-18-2015, 09:03 AM
bluebee's Avatar
Today, another radiator nipple was broken.
- > E39 (1997 - 2003) > Emergency radiaotr issue.... Please Help !!!
Old 06-20-2015, 10:25 PM
bluebee's Avatar
It may be that nipples come in sizes...
> E39 (1997 - 2003) > The Radiator overflow nipple
Originally Posted by nalaleah53 View Post
I see there is much written on removing broken radiator overflow nipples, but I have a different question. I have just replaced the radiator on my 1998 528i and also replaced a probably perfectly good expansion tank and overflow top hose. (I'm surprised more people don't complain about this hose. If it was 2" longer, it seems like routing it from the tank to the nipple would be a lot easier.) My new hose is very stiff and barely allows it to connect at both ends. After bleeding the system, there is a leak at the nipple and I can easily rock the nipple and see the leak. I bought an extra nipple not knowing if my bargain radiator had one. My question: Is the short new hose likely the problem "rocking the nipple out", or is it just as likely, the nipple doesn't seat well in the radiator?
Old 07-27-2015, 11:53 AM
bimmerZ5 bimmerZ5 is offline
Mein Auto: Z3 3.0i Rdstr, E39 530i
bluebee: I have a E39, but I seem to work on my neighbor's E39's a lot more and encounter new problems I haven't seen before. Every time I do a search, I inevitably end up on one of your threads! LOL ... do you have an indexed and searchable "book of E39 repair & maintenance" thread that links to all the various discussions?
I ended up on this thread because my neighbor is having a tiny leak at this elbow. Over the years, I've found that a lot of O-rings on BMWs have a high failure mode due to compression set. I've slowly been collecting info on various O-rings as I find them and finding suitable replacements that I think last longer. In particular, using Viton O-rings seem to do the trick and I have less people coming back to me to help them fix their BMW's leaks. (i'm sort of the neighborhood BMW repair guy - only by hobby not a pro)
To that end, has anyone pulled the O-ring off and taken some measurements? Outer Diameter? Inner Diameter? Or thickness? That would help me hunt for the right size Viton O-ring...
I plan to try to remove the part intact, as I replace this guy's radiator w/ Behr one (his choice) about a year ago; I don't think the plastic is too brittle just yet. I see the two tabs are not for retaining, but probably just to hold position so the piece is pointing in the right direction. I plan to spray some WD-40 around it and let it sit so it seeps in and helps lubricate the O-ring. I've used this technique on removing the radiator hose connections when they've seized on the O-ring and it helps a lot. Also, getting a assortment set of pry tools meant for taking apart cell phones might come in handy; there are usually a variety of very thin pry tools (thinner than screw drivers) made out of plastics and even metal. I don't know where I got my kit as my wife got it for me as a present one year, but prying little things like that has been a lot easier with that kit. Once it comes out enough, I will then use a screwdriver or other typical prying tools I have in the garage. I also have a trim panel removal tool set that looks like this that I will bring with me in case it might be of use in this situation.
Anyway, just sharing my thoughts/approach on this task. I haven't actually done it yet, waiting for my neighbor to get the parts, but will report back on what works or didn't work.
Anyone help with the O-ring size would be great... if anyone has this part lying around, please take measurements. Thanks!
