Old 08-02-2010, 08:29 AM
Takechan Takechan is offline
E39 fanboi
Mein Auto: BMW E39 520i (M52B25)
M52 starter motor removal, can it be done without removing intake manifold?
Hi,
I'm aware that cn90 has posted a semi-diy, where it states that you can uninstall/reinstall the starter motor on a manual transmission engine from the bottom. However, it seems like a very long way up from the bottom, given the starter is located not far below the intake manifold.
Has anyone here removed the starter on an I6 from the bottom, without removing the intake manifold?
Old 08-02-2010, 11:56 AM
Mark@EAC Mark@EAC is offline
Past Sponsor
Send a message via AIM to Mark@EAC
Mein Auto: e39 5
if you remove the drivers side cabin filter housing and duct you may have just enough room to get it in and out. The hard part will be the bolts. Also, you will need "female" torx socket to remove the bolts. Pick up a cheap set at harbor freight tools. http://www.harborfreight.com/6-pc-3-...set-95395.html
Old 08-02-2010, 12:13 PM
E39 fanboi
Thanks Mark, i'll give it a shot!
Old 08-02-2010, 05:36 PM
jarhed1964 jarhed1964 is online now
Mein Auto: '99 528i Sport, '05 530i
PITA, but it can be done. I only lost a half pound of knuckle skin and gained a few tools replacing mine.
Old 08-02-2010, 08:25 PM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
The quickest way I find is from below using:
Torx socket, swivel, 3ft extension, ratchet w/ cheater pipe.
Best is w/ torx socket w/ built-in swivel, 3 ft extension, ratchet w/ cheater pipe.
ONce the two main bolts are removed, from below engine, unthread the cable clamp that's bolted to the engine block below the starter. By doing so, this allows the space for the starter to drop down to the ground. Then slide starter out of bell housing, shift and lower it down to the ground.
If you do this right, you should be in and out of this repair in under 30 minutes.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 08-03-2010, 02:22 AM
E39 fanboi
Thanks guys... I knew it'd be a PITA - we should create we "we replaced our own starters" club lol
Old 08-05-2013, 01:26 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For the record, this question came up again today ...
- New starter in my future! Any DIYs for replacing on the M54 from underneath?
