Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 08-08-2010, 03:46 PM
gordonkelvin81 gordonkelvin81 is offline
Mein Auto: bmw 740il
96 740iL - P code errors
what does codes p0300, p0306, p0306II, p0308, and p0308II means on OBD Codes for a 1996 bmw 740il
a
Old 08-08-2010, 04:37 PM
balance balance is offline
Mein Auto: 97 740iL
PO-300, random/multiple cylinder misfire
PO-306, cylinder 6 misfire
PO-308, cylinder 8 misfire
I have no idea what the "II" means.
I would pull those plugs and see if they are either covered in oil, or fouled. I'd imagine that you either need a tune-up, valve cover gaskets, osv plate (vaccum leak?), or all three.
You can try putting those 2 plugs in a different cylinder, as in taking the plugs on the driver's side and swapping them with the passenger side plugs and vice versa, and see if the error codes follow the plugs. If they do, then you only need to change plugs, if they don't then you either need coils or valve cover gaskets.
HTML code is Off
