Long crank to start part II - Bimmerfest - BMW Forums
Old 08-09-2010, 04:36 PM
Chancevought953 Chancevought953 is offline
Mein Auto: 2011 X3
Did anyone ever come to a final conclusion as why their X3 had a long crank time to start? My 04 has been all over the map. Fires right up. Other times takes 3-4 seconds. Yesterday on 3 different occasions it took 7 to 8 sec and once it didnt start on the first try.
I had the fuel pump replaced a couple of weeks ago. I initially thought it corrected the problem but within the last week, much to my dismay, the cranks again have become longer.
There is NO pattern to it. Hot or cold. Pausing the key, nothing makes a difference. Sometimes fires right up, other times not. I dont get it? All I can find on the forums is Crank position sensor, or fuel injectors getting replaced ($$$$) or the fuel pump.
Anyone get a real fix for this?
My sister n laws 04 X3 fires right up everytime. Which tells me something is not up to speed on mine.
Thoughts?
2011 X3 2.8
Old 08-09-2010, 07:53 PM
minicrazy592's Avatar
minicrazy592 minicrazy592 is offline
about the mini part....
Mein Auto: E90 M-tech, E30 M-tech
Mine did this right before we sold it, it ended up being the fuel pump on ours. It did the exact thing you are describing. Gotta see if I can find the invoice and see what exactly they did.
-J.T.
Will be missed: 04' E83 M54B30
Old 08-09-2010, 08:01 PM
kjboyd's Avatar
kjboyd kjboyd is offline
Drink the koolaid or else
Mein Auto: 2015 X1 sDrive XLine
there is actually a tech bulletin for this problem. software update will fix it. it's SIB # 12 49 06
This Service Information bulletin supersedes S.I. B12 49 06 dated November 2006.
designates changes to this revision
SUBJECT
DME MS45 - FC28B2, 28AA, 28AC; Internal RAM Faults
MODEL
E46 M54 with MS45.1 from 9/00 to 7/06
E83 M54 with MS45.0/MS45.1 from 9/03 to 9/06
E85 M54 with MS45.0 from 10/04 to 1/06
E60 M54 with MS45.1 from 9/03 to 3/05
SITUATION
Customers may complain about a crank/no start or a rough start situation. The "Service Engine Soon
Light" or the DSC light is illuminated, and one of the 3 scenarios may apply:
1. FC 28B2 "rpm limiting reset " is stored in the DME together with one, or more of the following
faults which are caused by the 28B2:
***56256;***56443; FC 28AC - "nominal torque",
***56256;***56443; FC 2796 - "throttle flap: adaptation wrong",
***56256;***56443; FC 27A1 - "throttle flap: start check",
***56256;***56443; FC 2869 - "DME self diagnostic: RAM check failed".
2. FC 28AA "idle speed regulator" is stored in the DME.
3. FC 28AC "nominal torque" is stored in the DME.
CAUSE
Fault codes 28B2, 28AA and 28AC indicate an internal DME RAM fault.
PROCEDURE
Perform the appropriate DIS/GT1 test modules for the 28B2, 28AA or 28AC.
Replace the DME if prompted by the DIS/GT1 test module results.
Important: Do not replace the throttle body for the throttle faults, stored in conjunction with FC28B2,
even when the test plan recommends to do so.
Kevin
2015 X1 sDrive XLine - "Hamilton Maxwell"
2009 MINI Cooper Clubman - "Oxley"
2007 Volvo S60 2.5T
2007 X3.0si PlatBronze/Beige
2006 X3 3.0i, Flamenco Red/Beige
1997 528iA, Oxford/Tan
1994 318iS, Black/Gray
1979 528iA, RubyRed, Tan
1971 2002, Sahara, Saddle
Old 08-09-2010, 08:23 PM
Well they had to replace my disintegrated fuel pump first.
Then it spent a month in the shop trying to get that bulletin right.
-J.T.
Old 08-10-2010, 06:48 PM
Mein Auto: 2011 X3
Thanks,
The X3 going back to the shop tomorrow. I will show him this SB
2011 X3 2.8
Old 08-11-2010, 06:21 AM
X3-terrestrial's Avatar
X3-terrestrial X3-terrestrial is offline
Aficionado
Mein Auto: '05 X3, '02 M3, '91 E30
Originally Posted by kjboyd View Post
SITUATION
It happens to me from time to time, maybe 2-3 times in a month, but since none of the lights are on I don't think this TSB would apply in my case. And is not getting any worse, so right now is not to the point that I would consider it a problem.
Old 08-11-2010, 10:47 AM
enamoured enamoured is offline
Mein Auto: 2005 BMW X3 3.0i
+1, same here. Happens intermittently (3-4 second crank) with no lights on dash. I am thinking mine would be batteries, they are 5 year old now; drained once in winter and needed boost.
(OO \ (|||) (|||) / OO)
Old 05-26-2012, 01:29 PM
NICAZOID NICAZOID is offline
Mein Auto: 2005 BMW 330CiC
My 05 330CiC does this. Has same engine. Letting the key sit in the on position until a second after beeps stop is the only way to get it to start almost instantly. Otherwise its random amount of cranks.
