Pedal Position Sensor Pot failing - Bimmerfest - BMW Forums
E46 (1999 - 2006)
Old 08-12-2010, 03:17 PM
mrblorry's Avatar
mrblorry mrblorry is offline
No User Serviceable Parts
Mein Auto: '04 545i, Schaltgetriebe
Unhappy Pedal Position Sensor Pot failing
Crap! Another SES light! I got this error on Monday, I cleared it, and it reappeared today; about 100 miles between instances:
Carsoft says:
168 Pedal position sensor potentiometer supply channel 1
...and I believe this is the generic equivalent:
P1624 Pedal Position Sensor Potentiometer Supply Channel 1 Electrical
My searches yielded no helpful results, other than it's not uncommon. My accelerator pedal is also crunchy, for which a TSB was created several years ago, and I'd LOVE to remedy that problem, but clearing the SES is more important. Perhaps I can do both in one shot?
Is replacing the accelerator pedal module the answer? (see the attached image, label #1, part # 35426786282)
Does anyone know if that will solve my SES error? Is there a DIY anywhere, or perhaps someone has the TSB? If anyone has done it, is it a PITA?
-Steve
Old 08-12-2010, 05:41 PM
Tangent's Avatar
Tangent Tangent is offline
Format c:\*.* /y
Mein Auto: '11 Z435i, '01 330i
If the code is generated by the fault in the pedal assembly, it should clear itself after you replace the assembly. Removing the assembly is very simple. Press down on the clip you see on the side of the assembly and push the whole thing to the left
Old 08-12-2010, 05:51 PM
mrblorry's Avatar
OK! Thanks for the input! Do you know if there are other conditions that would cause this error code that I could troubleshoot? The pedal assembly is a pricey part; something I was planning on replacing in the future once monies begin flowing again, but was willing to live with until then. However, if the SES light keeps coming on, I don't really want to have a "Toyota" on my hands! WOT without warning is not fun, especially in a reasonably fast car.
-Steve
Old 08-12-2010, 06:27 PM
Cliff Cliff is offline
TMS
Mein Auto: 2015 Golf R
I can't directly answer your question, but I can say that the pedal assembly was the only part listed on the service invoice I have from the dealer for the repair of this TSB, and p/n 35426786282 is what they installed.
2015 VW Golf R: (pic)
Old 08-12-2010, 06:39 PM
mrblorry's Avatar
Thanks Cliff. I found two TSB numbers. Do either of these look familiar? 67665 or 106671 or NHTSA number 635883
-Steve
Old 08-12-2010, 06:52 PM
TMS
I was looking for a TSB number referenced on my invoice and I found nothing. I'm afraid I can't help you there.
Old 08-12-2010, 07:00 PM
mrblorry's Avatar
Well, thanks for looking! Now the big question! Did that repair solve the sticky accelerator?
-Steve
Old 08-12-2010, 07:03 PM
TMS
I didn't have one, but I wasn't about to ignore a TSB while the car was still under warranty either. The repair was done in October 2002, about 4 months after I took delivery. I can say my accelerator isn't throwing codes...
Old 08-12-2010, 07:15 PM
mrblorry's Avatar
You know, heheh, I probably hosed my own accelerator in an attempt to smooth out the stickiness. I shot a decent amount of WD-40 down the shaft.
It didn't help at all, and now the unit is throwing codes.
-Steve
Old 08-13-2010, 03:55 AM
mujjuman mujjuman is offline
tappa tappa toit
Mein Auto: hoopty
damn man... our pedals are electronic....
i think you damaged your pedal and the elecetronics in the assembly. you might just have to replace and call it a day... or a weekend
mujjuman
Old 08-13-2010, 08:20 AM
mrblorry's Avatar
Well, it still works, and I've driven it this morning, and the SES light didn't come back on, but I just know it's going to. I tried removing the accelerator just to see what's in there, but I can't move it.
Tangent says it's an easy removal, but I must be pressing the wrong tab or something. Anyone removed their accelerator pedal?
-Steve
Old 08-13-2010, 08:33 AM
TMS
These should help some.
Old 08-13-2010, 08:38 AM
mrblorry's Avatar
Cliff-
I don't know what to say, but thanks a million.
I was just going to remove it to see if there was anything to clean, such as contacts, etc, but the FIRST thing I read from your pdfs (see attached).
Now I know I better have a new one right beside me before I attempt this!!
-Steve
Old 12-07-2010, 06:31 PM
phamine phamine is offline
Mein Auto: 94 Honda Prelude
Did you ever replace the pedal? Did it remove the code?
Old 12-07-2010, 06:35 PM
mrblorry's Avatar
Yes, and yes. Well, I had to clear the code, but it did not return.
-Steve
Old 12-07-2010, 06:42 PM
Thanks.
I began getting this code as well as "mix deviation" codes. I think they are somehow related.
I'm ordering the pedal. hopefully it'll solve my problem.
Old 12-07-2010, 07:00 PM
mrblorry's Avatar
Gently press on the release tab behind the notch (left bottom middle of pedal housing) and slide the assembly toward the brake. It appears the base is brittle; my release clip broke off, and I had to buy a new base. (Note the red circles on the diagram for locations)
-Steve
Old 12-20-2010, 07:12 PM
Replacing the pedal did not work. Does anyone have the ETK to trouble shoot this code?
