Old 08-13-2010, 11:40 AM
ants4three ants4three is offline
Mein Auto: X5 and Z4
Brake pads
Which brake pads are the best to get for 2006 3.0si?
Old 08-13-2010, 12:24 PM
SUNZOUT SUNZOUT is offline
Mein Auto: '00 M Roadster
Impossible to answer...
There is always a comprise between comfort/performance/price.
Do you want to track the car, autox, fast street, slow street?
Low dust or don't care?
low noise or don't care?
price range?
TC Kline S/A Coilovers | Sharked | Turner Slotted Rotors | Axxis Ultimate Pads | SS Front Strut | IE Subframe Bushings | IE Rear Toe/Camber Kit
Whalen Shift Machine | Stygar Clutch Pedal | CDV Delete | LeatherZ Armrest | Whalen seat bushings | Z3Solutions Windblocker | Shift Pin fix
Old 08-13-2010, 12:31 PM
I want the low dust, for fast street, low noise and price range around the $50-$100.
I've been reading on some reviews and so far Akebono seems to be the ones with the best reviews.
Old 08-13-2010, 03:09 PM
craig01b craig01b is offline
Mein Auto: 2003 z4
Akebones work ok...brakes are not something you want to cheap out on....when you need them, they had better be there. Full race ceramic,which don't work well until they are heated up, are not great for day to day driving, which is what we do most of the time. Lots of good aftermarket stuff out there...just stay away from the cheapest..IMHO...
C
Old 08-13-2010, 03:55 PM
Giznaz Giznaz is offline
Need a tow?
Mein Auto: '99 Z3 2.8/'11 X3 35i
Axxis Deluxe Plus or whatever they are calling them now. Pagis is the exact same
Old 08-13-2010, 04:12 PM
Mein Auto: 2003 z4
Jurid, pagid...all good
Old 03-04-2011, 10:47 PM
papitosabe's Avatar
papitosabe papitosabe is offline
WalkTheWalk
Mein Auto: 06 Z4 Coupe
so what are the diff in pads.. as far as akebono fronts, there is one for the roadster and one for the M... is that difference based on wheelsize or the rotors that are used or something else?...i have an 06 coupe and put 19's on them...oem pads and rotors...so should I just purchase the roadster pads? (there are no coupe ones)
Old 03-05-2011, 07:44 AM
Use Realoem.com to check part numbers and what models the fit.
Look up your car, find the part number they specify and then use the option to list all the other models that use the same part.
I would expect for the Z4 it's the same as the Z3 in that the M got different size Calipers therfore different size pads.
example
Coupe Z4 3.0si has part number 34116779652 for front pads
and is the same as these models.
E46: Details on E46
E46 330Ci Coupe
E46 330Ci Convertible
E46 330i Sedan
E46 330xi Sedan
E85: Details on E85
E85 Z4 3.0si Roadster
E86: Details on E86
E86 Z4 3.0si Coupe
Old 03-05-2011, 08:55 AM
Mpire's Avatar
Mpire Mpire is offline
The Anti-Rice
Send a message via AIM to Mpire Send a message via MSN to Mpire Send a message via Yahoo to Mpire
Mein Auto: S54 M Coupe x2, M52 Z3
I really like the axxis metal-master pads for reducing the dust.
They also stop much better than anything they sell at Autozone.
2001 Alpine / Schwartz Coupe
2001 Estoril / Estoril Coupe
2001 Steel Grey / Estoril Coupe
1999 Estoril / Estoril Coupe
Sunroofs are for girls.
Old 03-05-2011, 10:00 AM
CalRick CalRick is offline
Mein Auto: 2007 Z4MC & 95M3 Tracktoy
The Z4M and the 3.0si use the same pattern pad in the front despite the different rotors (same as my E36M3, for that matter); BMW specs a different compound between the two. The rears are different profiles. If you look it up on the application tables for the aftermarket suppliers you will see this - then it's just a matter of choosing the appropriate compound for your use. I will defer to others' opinions for street compound as I have mostly played around with track compounds, though the Axxiss Ultimates and PFC Z's both seem to be popular alternates to the OEM BMW pads.
