E30 (1982 - 1993)
Old 08-14-2010, 12:46 PM
faviolosky faviolosky is offline
registered bimmer user
Mein Auto: 325e 1987
guibo BOLT
for some reason i guess i forgot to tighten one guibo bolt and it fell, now i have been experiencing an crazy vibration after 40mph.
is this what may be causing the vibration???
if so does anybody know what are the size and thread of the bolt and nut so i can put it back before anything else messes up.
Old 08-14-2010, 03:53 PM
eieio4tn's Avatar
eieio4tn eieio4tn is offline
BMW...riceless
Mein Auto: 1987 325is
big yess...remove one and go to hardware store, match it up.
Old 08-14-2010, 04:52 PM
lordofthewaters's Avatar
lordofthewaters lordofthewaters is offline
Rather Large Member
Mein Auto: 88 325is 04&09 jetta TDi
M10x52 you'll want a heavy duty bolt.
Sarcasm is a body's natural defense against stupid.
When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's 3.95 per minute.
"My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson
Old age and treachery, will always overcome youth and skill.
Old 08-14-2010, 05:04 PM
eieio4tn's Avatar
BMW...riceless
was going to say grade 8.
Old 08-16-2010, 09:27 AM
actually it was M12 and i went to home depot and got a steel m12x60mm and a nut and its working great but its only temporary till i can find the right one. i think im going to NAPA or autozone to special order one or something.
Old 08-16-2010, 10:27 AM
Pennyw1se Pennyw1se is offline
Mein Auto: 1988 325e
http://www.realoem.com/bmw/showparts...23&hg=26&fg=10
Shows the bolt is M10X50. Ive always had good luck at Ace Hardware.
Old 08-17-2010, 04:21 PM
thats for the smaller guibo, i got the later bigger one with m12 bolts.
Old 10-02-2013, 02:21 PM
Nick22Garner Nick22Garner is offline
Mein Auto: 1988 325is
i have a similar problem on my e30. i went to bmw and reluctantly forked over 4.50 for a bolt... however i went to put it in and it would not get tight. is this because i have an bigger guibo or because the threads are worn? do you think i could re thread by drilling or should i get a new guibo from a junkyard or a new one from a parts distributor? The previous owner put longer bolts in and a lock nut on the back of the bolt used to remedy the problem? I don't see why that couldn't work??
Old 10-03-2013, 06:01 AM
toybuilder's Avatar
toybuilder toybuilder is offline
Mein Auto: 89 325i 2dr&DucatiMonster
I don't see what your drilling guibo's don't have threads.You want to put bigger bolts in your guibo? WHY ? The guibo should have 6 bolts and 6 nuts with washers that hold it to your transmission , I warn you modifying or using multiple types of nuts and bolts can cause a serious vibration and should only be done as a temporary fix. The correct parts are available at your dealer or BAV Autosport or 10 other reputable suppliers .It's not worth screwing your car up over 30 bucks worth of new bolts.If you have 135mm guibo on your car and not the correct 110mm guibo someone has put the wrong transmission in your car .
