Old 08-16-2010, 11:31 PM
mr boomerang mr boomerang is offline
Mein Auto: 2000 e39 528i///M package
Exclamation my A/C will only work sometimes either on MAX or OFF!!
so i have a '98 528i m-sport...i'll have the temp down to 69 degrees F and have it on auto and it WILL NOT blow air...not even if i take it off auto and put the bars all the way up manually...it WILL NOT blow...UNTIL about driving the car for a half hour...then it will blow on max for about 10 seconds, then turn off...i took it to a mechanic who diagnosed the problem being the greenish white relay underneath the hood that controls the blower motor...before i go out and spend $90 on a relay, would this be the cause of the air not blowing?? thanks
Old 08-17-2010, 02:54 AM
99SK04GTX 99SK04GTX is offline
Mein Auto: 2002 540i
Sounds like a typical FSU problem, Final Stage Unit, Final Stage Resistor.
Search this forum for "FSU"
Old 08-17-2010, 02:12 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
If it is the FSU, you don't even have to search the "forum"; just search the bestlinks sticky at the top of this forum for "FSU".
Old 08-17-2010, 04:43 PM
jarhed1964 jarhed1964 is offline
Mein Auto: '99 528i Sport, '05 530i
Probably the EASIEST fix you'll ever perform. Enjoy it, many more harrowing, annoying, confusing, and maddening fixes will come your way soon.
ac, air, blower, conditioning, motor
