Old 08-19-2010, 04:29 PM
ShaunT ShaunT is offline
Mein Auto: '98 740 IL
98 740iL O2 sensor, cam sensor code? & other ?'s
1: I have a sensor 1 bank 1 code. Which side is bank 1?
2: Is it a heavily involved project to get to the Cam sensor on this Engine? (I have a Cam Sensor code.)
3: Who sells a replacement front Grill for this car that looks original and is priced fairly? The right side either fell off or someone took it. Am I stuck with having to buy it from the BMW Dealer if I want one that matches the original one on the left side?
Thank You.
Old 08-19-2010, 05:15 PM
balance balance is offline
Mein Auto: 97 740iL
1. Bank one is passenger side in the E38
2. The easiest cam sensor I have ever had to change has been on my 740
3. If I was looking for a replacement grille, I'd check out ebay
Old 08-19-2010, 06:01 PM
Excellent.
Thank You!
Old 08-19-2010, 08:57 PM
HLB HLB is offline
Mein Auto: 1997 740il
You could also check out http://www.pelicanparts.com/euro/cat..._pg1.htm#item0 which is where I order most of my stuff from.
You could also check out the cam position sensor whilst you were on there. Not a difficult job at all. You could also check out eactuning.com for these parts.
Hope all goes well.
HTML code is Off
