Burping the radiator - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 08-19-2010, 05:50 PM
joeusmc1985 joeusmc1985 is offline
Mein Auto: 1992 E36 325i
Okay, so, on my 92 325I, I've just installed a new radiator. I've been burping the system for well over an hour, and there is still bubbles coming up. Suggestions?
Sent from my Droid using BimmerApp
Old 08-19-2010, 06:14 PM
There are no visible leaks from any hoses, or any other part of the cooling system. Everything is brand new; radiator, fan clutch, thermostat, thermostat housing, and external cooling tank.
Old 08-19-2010, 06:18 PM
Killjoy's Avatar
Killjoy Killjoy is offline
OEM Hoe....
Send a message via AIM to Killjoy
Mein Auto: 1999 M3, 2002 tii
Did you have your heater running? I did this myself, but I forget whether you're supposed to run the heater while flushing the coolant or when bleeding the system. Check here: http://www.pelicanparts.com/BMW/tech...lant-Flush.htm
Ninja Edit: If you don't mind my asking, what was you're MOS?
Originally Posted by Cmy_bimmer View Post
Oh your talking about THAT hole.. yeah thats an inspection hole
Old 08-19-2010, 07:23 PM
wag-zhp's Avatar
wag-zhp wag-zhp is offline
Mein Auto: 97 White 328iC
I find that elevating the front of the vehicle helps the bleeding process a great deal. The front doesn't have to be much higher, anywhere between 8 to 24 inches will be fine, so even a sloped driveway will help. With the front end elevated, 1) start the car, 2) set the heater to full hot and run the blower, 3) add coolant until no more air exits through the bleeder screw, 4) rev the engine up to about 3k rpm and then let it return to an idle, 5) add more coolant until no air exits through the bleeder screw, repeat steps 4 and 5 a couple of times and then button everything up.
When it absolutely, positively, has to be destroyed overnight! OohRaah!!!
U. S. M. C.
Semper Fidelis
Old 08-19-2010, 08:12 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
And then repeat the process for the next couple of days to be sure.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
