Old 08-20-2010, 01:09 AM
HLB HLB is offline
Mein Auto: 1997 740il
MAF sensor housing crack
Hi,
The PO had an issue with the fan and it basically fell apart. A small section of blade lodged into the MAF housing causing a small crack and air to obviously leak through. Luckily that was the only damage.
Does anyone know what effect a tiny leak like this would have on the bottom of the MAF?
Does anyone also know what volumes or speeds air can potentially pass throught the MAF?
Interesting discussion.
Old 08-20-2010, 01:10 AM
HLB HLB is offline
Just to clarify, does anyone know what effect this would have on performance?
Wording in previous post was ambiguous.
Old 08-20-2010, 03:14 AM
CodyItaliano's Avatar
CodyItaliano CodyItaliano is offline
Mein Auto: 2001 740i
do you mean the cylinder section that the intake tubing attaches to? if the sensor itself is still good and the housing you say just has a crack, JB weld is your friend, or a plastic compatible epoxy. you can buy a new one on oembimmerparts.com for about $200 shipped though. but yes, any air leakage around the sensor will cause problems.
*Der E38*
manufactured: 7/01
color: anthrecite metallic
wheels: style 89 E66, 19X9F 19X10R
ext. lighting: 8000k D2S & LED plate light
*want to get sport rear diff*
Old 08-20-2010, 04:16 AM
HLB HLB is offline
Yeah its the cylinder section where the MAF is screwed in with two screws. Its fixable without buying a new one. The sensor itself is fine.
I was just wondering with a perfect sensor and the small leak what effect this would have on performance.
Old 08-20-2010, 05:05 AM
any air leak around the sensor is bad. try and seal it
*Der E38*
manufactured: 7/01
Old 08-20-2010, 07:58 AM
balance balance is offline
Mein Auto: 97 740iL
I agree with CodyItaliano, and if it was my car, I'd probably JB weld it myself.
What the MAF does is meter the air coming into the engine, and adjust fuel to match it to make the best air/fuel ratio for a certain RPM. If unmetered air enters the motor, then the air/fuel ratio will be off, causing hesitation, rough idle, misfiring, and if it is bad enough, will cause the engine to shut off while it is running.
air, e38, maf
HTML code is Off
