Old 01-22-2011, 11:28 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Originally Posted by filon102 View Post
Bought this one for 65 w/ shipping... will report back with results
How is it working out for you?
BTW, here's another pic of the OBDII connector, for newbies, from QSilver7:
Old 01-24-2011, 12:08 AM
bluebee's Avatar
Today, someone asked what Carsoft can do (over here in the OBDII freeware thread) so I pointed him to the VERY best of E39 Links but the Carsoft threads weren't easy to find in the VERY best of E39 Links ...
So I just now added the following to help others (as always):
- Description of Carsoft, GT1, INPA, DIS, EDIABAS, & Peake (1) & which can modify the auto-lock car door feature (1) & what does Carsoft do anyway (1) (2) (3) (4)
Old 08-22-2011, 07:22 AM
Breckenscott Breckenscott is offline
Mein Auto: United States
Just picked up the Equus 3030 Innova for $45 on Amazon... happy with it so far, it reads the standard OBDII codes as well as the BMW-specific codes on my 2001 E39.
Old 09-01-2011, 09:23 AM
bluebee's Avatar
For the record, we've organized the most often recommended freely available software for diagnosing the E39 over here:
- The most often recommended BMW diagnostic tools & cable interfaces (1)
Old 10-28-2011, 12:16 PM
bluebee's Avatar
For the record, now that decent diagnostic trouble code scanners are in the twenty-dollar range, more and more of us are keeping a spare in the glovebox, especially in the states where free code scanning is illegal:
- E39 (1997 - 2003) > Code Reader?
Originally Posted by cn90 View Post
I just bought Autel MaxiScan MS300 from Amazon for $22. This is great as a glovebox item for long trips far away from home.
Originally Posted by QSilver7 View Post
Ditto...I carry one in my "daily driver", too. For 20+ bucks it's cheap insurance to have on hand as you stated. And if you live in one of the few states that don't allow places like AutoZone to do free OBD II scanning...it's very much worth the 20 bucks to be able to quickly check your codes if you get a CEL/SES...and not have to take the car to a certified mechanic to scan your vehicle.
Old 10-29-2011, 07:04 AM
MightyShilling MightyShilling is offline
Glutton for Punishment
Mein Auto: 2000 540it, 1988 951S
There is also an android app called Torque. Combined with a Bluetooth OBD II scanner, it turns your phone into a very effective scan/diagnostics tool. It not only reads codes, but will provide info such as oxygen sensor voltages, fuel trim, throttle input (%), etc.
Sent from my DROID X2 using Bimmer
Old 10-29-2011, 10:24 PM
aspensilver540 aspensilver540 is offline
Mein Auto: 1997 540i
Thanks bluebee! I bought this, read the instructions, and total time in the car was under 5 minutes getting the code. Of course i have no idea how to solve my code, but at least I identified it
I highly recommend the Autel for ease of use and price. It'll stay conveniently in my glove compartment.
Old 10-30-2011, 04:57 AM
bluebee's Avatar
There is only one answer of what to do once you get a PCODE.
See it repeated in this thread yesterday when the same question was asked:
- Code Reader?
Old 07-05-2012, 11:38 AM
bluebee's Avatar
I just bought another one of these and the Amazon price is down to about $20.50 + about $5.50 shipping for a total of $26 (or free shipping if you can jack the price up above $25 by buying two of them and saving them to give to friends that help you work on your bimmer - which is what I do)...
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 07-05-2012, 11:44 AM
Fudman's Avatar
Fudman Fudman is offline
You know you are becoming a grease monkey/gear head when you give car repair tools as gifts!!!!
Old 07-05-2012, 01:47 PM
crazy4trains crazy4trains is offline
Mein Auto: 2002 530i Sport
So, how well does this one work and what are the limitations?
Thanks.
2002 530i
Old 07-05-2012, 03:06 PM
Calicoastin Calicoastin is offline
Mein Auto: 2003 E39 540i auto
I know this isn't much but it's $1 less (with shipping) from fleabay. Just lookup "maxiscan".
FS: E34 B30 V8 engine intake manifold with throttle body and rear cover....$70.
Old 07-05-2012, 03:15 PM
540 M-Sport's Avatar
Mein Auto: 01' 540 M-Sport cdn, F355
ELM 327 scanner on Ebay
Factory M-Sport with factory installed M-tech bumpers, factory Bluetooth, factory M-Audio 10" dual voice coil subs, homelink, M5 rear stabilizer bar, Bilstein B14 PSS coil overs, stop tech ss brake lines, Akebono Euro Ceramic brake pads, oem Brembo and Zimmerman rotors, Dinan Stage 1 software, strong strut front upper stress bar.
Old 07-05-2012, 03:16 PM
These are now less than $10 on Ebay with shipping, still a superior option if you own a laptop.
Originally Posted by 540 M-Sport View Post
Assuming you own a laptop, the absolutely cheapest thing out there is an ELM327 scanner purchased off Ebay. I have recently seen them selling for $21 delivered, and they even include the freeware/software on a cd rom. I have been using one for a over two years now and it works great. http://cgi.ebay.com/ebaymotors/New-E...item1e5f088bb8 They make a cordless bluetooth version that sells for $36.
Three advantages to it:
1) It reads out sensor data too. So you can read O2 sensor voltages, to verify operation. It also reads out intake air temp, coolant temp, engine rpm, etc.
2) You have the option of purchasing even more sophisticated software to perform even more detailed readouts, graphing, etc.
3) Larger display
Not a bad investment for less than $25.
For ultimate simplicity, I would go with Bluebee's suggestion...simply and easy to use.
Old 07-11-2012, 12:18 PM
bluebee's Avatar
Works fine for the four things I need it for:
a) indicates pending codes
b) indicates triggered codes
c) indicates when the indicators are 'ready' (for smog inspection for example)
d) clears codes
The limitation is in the specifications. It's not fancy. It doesn't give freeze-frame data, for example. But, for me, that's what the BMW diagnostic tools are for.
Making sense of the most often recommended BMW diagnostic tools & cable interfaces (1) & BMW factory & dealer programming, coding, and diagnostic software such as INPA, EDIABAS, NCS Expert, DIS, EasyDIS, Progman (1) (2) (3) (4) (5) (6) (7) (8) (9) & related BMW diagnostic-tool forums (1) (2) (3) (4) (5)
Old 07-29-2012, 02:33 PM
King540i King540i is offline
Mein Auto: 7/98 NonVanos 540iA
I've read about 10 carsoft threads. I can't for the life of me figure out if Carsoft gives a a detailed diagnosis of the Air Conditioning system. Will Carsoft tell me exactly what is wrong with my AC? If so, how detailed? ie specific code for evaporator, fan, condenser, not enough refrigerant, ...
Also, does it do the same for auto tranny?
Old 07-29-2012, 05:47 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Any good indy can service the A/C. You need a vacuum pump and gauges.
Either you are part of the solution, or you are part of the problem.
Old 07-29-2012, 07:55 PM
bluebee's Avatar
This probably wouldn't be the right thread to ask that. I would think it should be covered in the Carsoft threads. I typed /carsoft F3 in the bestlinks and found this set ... which would seem like the right threads to ask that question of:
- What does Carsoft do anyway (1) (2) (3) (4) (5)
If I type /air conditioning F3 in the bestlinks, this comes up, among others:
- How to learn about (1) and set up your air conditioning (1) (2) & how to replace the activated charcoal cabin air filter (1) (2) (3) & what cabin filter to buy (1) (2) & cn90's inexpensive cabin filter retrofit (1) (2) (3) & cabin air filter implications for stinky gym sock AC odors (1) (2) (3) (4) & how to refill your A/C system for $20 (1) (2) (3) (4) & where to find your low pressure aircon recharge port (1) & what refrigerant PAG oil to use (1) (1) & R134a conversion information (1) (2) how to measure A C temperature (1) & how to diagnose A / C compressor knocking sounds (1) & air conditioner compressor replacement DIYs (1) or compressor rebuilds (1) or ac hose rebuilding services (1) & how to remove the IHKA air conditioning control panel to clean the circuit board (1) (2) (3) (4) with removal of MID, HVAC/IHKA, Business CD player (1), & dashboard trim (1) & how to remove the trim and bracket holding the MID & HVAC/IHKA panels (1) (2) or to replace the IHKA button (1) & how to check the IHKA sampling fan (1) & how to change OBC MID IHKA KTMP temperature from degrees Celcius to Fahrenheit (1) (2) (3) (4) (5) (6) (7) (8) & how to diagnose lack of HVAC/IHKA heater core heat with cooling system (auxiliary pump) at idle (1) & what is this thing (HVAC/IHKA solar sensor) in the middle of my dashboard by the windshield (1) (2) (3) (4) (5) (6) (7).
