dash pixels revisited 2002 e39 530i
There's been a few discussions about pixels of late. I need to get mine done, the speedo / mileage / on board computer readings ....
sometimes they are as bright as Las Vegas Lights, sometimes as dim as my brain is right now. My question is basically about the `ribbons` that are on offer from various suppliers. has anyone tried the `ribbon fix`? Or is the problem actually in the led circuit board. Any advice gratefully received Anyone used this place? http://www.pixelfix.net/eng/ Just by the way the abs module on mine has a mind of its own, I have checked and replaced a couple of the wheels sensors, Although I have never had any problems with speedo / cruise / not working. just that the lamps come on at their own will. I drove from Sunshine Coast to Gold Coast (OZ) this morning with two pit stops for coffee etc.. no lamps. Tonight lamps on all the way home from start up.. go figure. |
I have read to great lengths on this and other boards. What I have learned is that the ribbon fix is a major gamble. Unless you are very proficient with fine electronics and have a good understanding, I would stay away from a DIY.
I have been in contact with BMWUSA. Last week they offered me 50% off parts, plus labor. Others have gotten 100% off parts, but have had to pay for one hour labor (repaired through dealership). BMW tells me they are no longer offering 100% for parts. Sad thing is that the previous owner had the pixels fixed by the dealer in 03, and they are bad again. So that tells me if you send it to the dealer, it will probably happen again as they have NOT fixed the real problem. BMW offers a 2 year warranty.http://vdorepair.com/ on the other hand will repair the pixels and offer a lifetime warranty all for around $300. For an additional $45 they will install the chrome rings offered on the M5. To me, this sounds like the way to go. They are located in California. Ship out your instrument cluster overnight, and you will get it returned 3-4 days later. Just noticed you live in OZ, .......shipping may vary. L. Last edited by Luftpost; 08-23-2010 at 08:38 PM. Reason: Update |
What is the current situation? Do they no longer replace the instrument cluster free of charge (labor & parts)? BTW, look at this thread today... the cluster was replaced for $250. Last edited by bluebee; 08-23-2010 at 11:03 PM. |
yep I am `down under` thanks for that I may look into contacting Bmw OZ..........i`LL SAY HAHA NOW.!
quick question does the `new`pixel cluster need to be recoded when its returned? If not why I wonder don`t Vdo or others offer an exchange unit......... you could buy the new unit at a fee plus premium which is returned when you send old unit back. just a thought |
L. |
In fact, when I contacted the dealer two weeks ago before pursuing this whole thing, he said BMW had abandoned the entire program. BMWUSA is offering me 50% on parts, plus labor. L. |
I did the job myself. I think I got the ribbon from the place you mentioned. It was the place that operates from Hungary.
I took my display apart twice, 2nd time was far quicker than the first, as I knew what I was doing. 1st time I'd just intended to put in extra padding to press the contacts down more firmly. But I accidentally pulled the ribbon off and that was the end of that. Half the gold contacts came away from the ribbon and stuck on the board! So put everything back together and ordered the ribbon and did the job again two weeks later. It was a bitch of a job. Admittedly though I'd never done anything like it before. It's not a nice feeling when you start drilling holes into your display. (Though you can't at all see the surgery when it's all back together.) Far and a away the hardest part is perfectly aligning the ribbon back up and then somehow sticking it down and clamping it all back up together whilst maintaining that alignment. After a few days of perfect pixels I lost some again anyway. After a few months I'm at about 70%. In my case, I believe the reason for this is that there's three plastic tabs that hold down the metal plate that holds the ribbon down. First time I did the job, I broke one of those tabs and now there's not enough anchorage to hold the plate down properly. My parting advice would be - if you do the job be really careful. I found that over the last nine years the plastic in the vdo has become more brittle with age. Sim. |
I have an '02 530i. I bought the ribbon from Bulgaria and tried repairing the pixel problem myself. I drilled the holes (my torx head screws were 9's, not 10's like Edmund's, but I found a Torx head 8 would work too). I got partial pixels and ultimately after taking it apart c. 40 times (bought machine screws and nuts from Radio Shack as I stripped out leftmost threads in the cluster), I sent it to VDOrepair in California.
Biggest problem was getting new ribbon to conform to an S-shape. VDOrepair says they use a better ribbon. Another big problem is the fuel gauge and the Temp gauge don't have stops and it is easy to knock the calibration/alignment off. I also mashed the fuel gauge pointer when I put the lens housing back on. VDOrepair fixed everything (except Temp gauge does not go exactly to middle when car is warmed up) for $275 (well worth it). I also paid $31 USPS shipping with $1K insurance. They charge $35 for first gauge they replace, $25 for additional gauges (also got new dial face plate for $2 as I had bent mine). VDOrepair pays the return shipping. It has been over a month now (c. 2K miles) and the pixels read fine. Send off & return was about 1 week. Communciation was excellent. Tracker5950 Last edited by Tracker5950; 09-06-2010 at 05:09 PM. Reason: misspelling; additional Info |
| Bookmarks |
| Tags |
| abs, dash, pixels |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
