Welcome to Bimmerfest -- The #1 Online Community for BMW related information! Please enjoy the discussion forums below and share your experiences with the 100,000 current, new and past BMW owners. The forums are broken out by car model and into other special interest sections such as BMW European Delivery and a special forum to voice your questions to the many BMW dealers on the site to assist our members!
You are currently viewing the forum as a guest which does not give you access to all the great features at Bimmerfest including the ability to search, interact with existing members and the option to turn off contextual advertising in posts. Registration is fast, simple and absolutely free so please, join our community today! |
5 Series DIY
Knowledge Is Power! ~ The place for do-it-yourself threads on a variety of topics. Start a thread describing a particular job (oil change, cooling system overhaul, brakes, shocks and springs, etc.) or search for one you need help with! |
E39 Cai Diy?
does anyone know any good links for this?
With the fear of pissing off Vietsb for contradicting him (i may need his knowledge on a future suspension install)... why would anyone spend $250+ on a system that you can easily do yourself? Not only is it cheaper... but you get to spend quality time with your Bimmer!!! I spent like $15 bucks at Lowes plus the cost of the K&N.
You guys tell me if this looks like crap... notice that I built a little bracket to keep everything nice and tight! |
E39 Cai Diy
Seems to me that you'd want to extend that CAI lower (near the bumper) to avoid taking in a lot of heat from the engine compartment. I'm hoping to get one installed in my car either this weekend or next. Hope to have some pics on this website. |
I have heard from multiple credible sources that the oil on K&N filters is responsible for contaminating many a MAF sensor. I've heard this from independent shops, message boards, and a Dinan tech.
If you go for an aftermarket solution, you may want to consider paying the $50 to get a Dinan conical filter from a dealer and use it instead. Quote:
That will only occur if you over oil the filter. If you do it per the instructions you should not have that problem. Lots of people use way too much oil on the filter after they clean it. Light pink is the cole it should be, not dark red.
JB |
The MAF sensor on my E38 failed without a K&N filter (stock BMW) and I know that they are having problems based on the letter they sent about it (BMW now covers it to 7rs/70k miles).
Possibly the MAF sensor can fail also due to over oiling, but they are failing early also with stock filters. |
I would suggest that any increased air flow that DSPTurtle is getting with his well constructed intake is being negated by the heat in the engine compartment. 540s generate a LOT of heat in the engine compartment. That is why the stock air filter is enclosed and draws it's air from behind the front bumper through a snorkle. The installation and subsequent servicing of most of the after market cold air intakes that require bumper removal, although rare, can be subject to water ingestion. I opted for the AFE intake for ease of installation and servicing as well as no concerns about H2O. Their heat shield seals well and the whole thing works well. If you are still trying to do this cheaply try Mikes trach can heat shield - http://540i6.com/heatshield.html
This is the AFE. Followed by Mikes trash can.
Mountain driving is the best! slower traffic KEEP RIGHT. BMW(space)CCA member since 1984. Last edited by Tahoe; 08-25-2004 at 01:17 PM. |
However, MAF failure is common these days. [Not only with BMW.] Due to the sensativity and similar design of modern MAF sensors, most auto mfgrs are having issues with it. That said, resently, I've seen a a new MAF Cleaner introducred on the market, made by CRC. [the same company who makes Brakleen.] Obvioulsy its a significant enough issue that a they've invested in producing a product specifically to address it. The following is a link to a PDF from CRC explaining the problem as well as a link to the product brochure. ...They use an M3 in their brochure... so it *must* be good. I plan to pick up a can and try it out this weekend, I'll post my "SOTP" Dyno results later.
Sometimes it's all about the jouney... ![]() Past Bimmers: 1997 528i, 1995 M3, 1989 325ic 1987 528e, 1982 528e, 1973 2002 tii Last edited by VCOUI; 07-01-2006 at 11:27 AM. |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
