Old 04-01-2013, 10:26 AM
duamel duamel is online now
Mein Auto: 07 750Li e66
Side Mirror Not Adjusting
The side mirror on the passenger's side will not adjust. Every once in a while it will react to a command but other than that it does not respond. What could be going on?
1998 528i 2001 330CiC
Old 04-08-2013, 07:58 PM
I was just told at the gym today by my mechanic that it's a shifter mechanism (he used a different phrase). He said it's a $700 part that is a pain in the ass to replace and it controls the automated mirror tilt (which mine stopped doing). It also doesn't let me adjust it, I had to set it manually.
He recommended not changing it.
Anyone have any opinions, options or thoughts? Kinda sucks to be conscious of a malfunction.
Sent from my SGH-T999 using Bimmer App
Old 04-14-2013, 05:57 PM
Anyone? Bueler? Bueler?
Old 04-14-2013, 06:06 PM
First_745Li's Avatar
First_745Li First_745Li is offline
Mein Auto: 2003 745Li
When you say will not adjust.. Are you referring to the tilt function when you put it in reverse?
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 04-29-2013, 12:59 PM
Re: Side Mirror Not Adjusting
Negative, the physical adjustment. I have manually set it because the motor will not move the mirror. He won't tilt on reverse either.
It's apparently a device that mounts near the rear of the motor but I wasn't given much more information.
What's wild is that every once in a while the mirror will adjust to the right slightly then stop amd no further adjustment allowed.
Sent from my SGH-T999 using BimmerApp mobile app
Old 04-29-2013, 01:08 PM
Busarider Busarider is offline
Mein Auto: 745LI
Could be a contact problem at the toggle switch at the arm rest, try to open the switch and see if it's making contact.
Old 04-29-2013, 06:52 PM
collins912's Avatar
collins912 collins912 is offline
Mein Auto: 745i
Try taking it apart to see if anything could be binding and check for any loose connections.
'11 Acadia Denali
'07 Tahoe(SOLD)
'02 745i
'00 Avalon
'06 GSXR1000(SOLD)
Old 04-29-2013, 07:41 PM
Khabar Khabar is offline
Mein Auto: 745i 2005
are mirrors interchangeable between 330ci and 745i? They look identical to me.
Old 04-30-2013, 06:52 AM
Thesatman Thesatman is online now
Mein Auto: 2008 750LI
It could be a connection problem...but probably not at the toggle switch though. The toggle switch has to be to the driver side for the auto tilt to work (which you said it doesn't) and the toggle switch has to be to the passenger side to adjust it manually (whitch also doesn't work. So...if it is a connection problem it is most likely at the connection on the mirror. The fact that it is intermittently working seems to indicate a bad connection though.
Old Yesterday, 02:53 PM
FIXED
I just replaced the battery and the problem is fixed. Everything works as it should. Interesting...
Old Yesterday, 03:54 PM
Battery? That's interesting. Glad you fixed it and even more so for letting us know.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old Today, 07:01 AM
Originally Posted by duamel View Post
FIXED
Wow...seems like a new battery fixes everything on these cars. You must have been having other symtoms right?
Sport Package, Rear Entertainment Package, Comfort Access, Cold Weather Package, High Def Audio
