E46 (1999 - 2006)
Old 08-25-2010, 04:05 PM
B1scu1t B1scu1t is offline
Bimmer Rookie
Mein Auto: 2004 325i
Exclamation Auxiliary question...
So I installed the auxiliary plug this afternoon. Was enjoying using my iPhone to listen to XM and my iTunes UNTIL....
I plugged in my power cord for the iPhone and the radio went from AUX to FM. I hit the "mode" button and it goes to CD then back to FM. Huh....
So I go back home (cussing all the way) and proceed to take the dash apart convinced something came loose. Well, everything looks good so I plug the iPhone back in and it works!! Unplug, plug back in, try Pandora, try XM, try iTunes.... All is working.
Off I go back down the road on my mission and I'm jamming away when the iPhone pops up 20% battery left so I grab the power cord, plug it in and not two seconds later, BAM, back to FM. No AUX on the mode button. Unplug the power cord, hit mode, AUX comes back up and works fine.
So, does anyone else have this issue? Everything is installed correctly. It works great until I plug in a power source into the phone. At that point the radio no longer recognizes AUX. So it's not in the phone, it's in the car. Any ideas??
'04 Business CD BTW
Old 08-25-2010, 05:37 PM
kgbmw02 kgbmw02 is offline
Mein Auto: 2002 325i sedan
'04 Business CD BTW
Well, from what I know about the radio on the business HU, it works on a power antenna. So, the only thing I can think of is that your Iphone charger might be send too much juice thru the AUX cable and switching your option. This is just a guess I have the OEM aux cable set up, and i never had this problem, oh by the way I use a monster cable for my AUX. Good luck hope this helps.
Old 08-25-2010, 06:32 PM
Bimmer Rookie
Kg, I was kinda thinking the same thing, power back through the AUX. Maybe I will go find a Monster cable. Right now I just have the Belkin cable I was using in my semi.
I did everything just as in http://www.my330i.com/mod26.php#Q DYI.
I am wondering if I disconnect the battery and reconnect it if that would reset anything?
Old 08-25-2010, 06:36 PM
marinekilz's Avatar
marinekilz marinekilz is offline
Noone Special
Mein Auto: 01 E46 330 xi
reseting the battery will do nothing. I believe even the newer cars have this problem with the iphone either charging or being used at a ipod.
01 E46 330Xi
06 E92 328i ZSP
07 E92 335i ZSP
E9 One Day It Will Be Mine
Old 08-25-2010, 07:57 PM
Washburn's Avatar
Washburn Washburn is offline
Mein Auto: AW 330Ci ZHP
Monster cable might be the most overpriced thing ever - and horrible quality, anyway.
I'd get all my cables from here: custom made, no frills prices:
www.bluejeanscable.com
Old 06-13-2015, 05:48 AM
miloc miloc is offline
Mein Auto: 2005 X3 3.0i 6-speed MT
This thread is soooo old, anyhow, I just install an OEM AUX port and I am experiencing the same issue. Ipod by itself (not charging) it sounds great! When connected to the charger..... back to FM, no AUX option. Does anyone knows the solution? A monster cable will really fix the problem? thanks.
Old 06-13-2015, 09:20 AM
Roman-dude Roman-dude is offline
Mein Auto: 2011 335d
'04 Business CD BTW
Which AUX did you install? Thx
Sent from my SAMSUNG-SM-G900A using Tapatalk
Loving every mile of it!
adapter, auxiliary, iphone, radio
