Old 10-03-2010, 08:33 PM
starrock starrock is offline
Mein Auto: e39
wow, really?
Old 09-03-2011, 04:57 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
For the cross-linked record, today, JimLev provided nice aux fan test info:
- E39 (1997 - 2003) > Aux Fan Help
Originally Posted by JimLev View Post
The fan is controlled by the dual temp switch on the side of the radiator and the HVAC system.
Stage 1 is low speed from the HVAC panel or the 91 deg switch on the radiator and relay K21.
Stage 2 is controlled by the AC high pressure switch and relay K22.
Stage 3 (high) is controlled by the 104 C deg switch on the side of the radiator and relay K201, which gets power from fuse F75 (50 amp) behind the glove box. F20 and F105 powers K201.
You said the fan comes on when you turn the AC on so Stage 1 (low) is working which means the 2 resistors are good.
Pull the connector off the dual temp switch and jump it to see if you can get.
Jumping pins 1 to 2 should make it run at high speed and pins 1 to 3 for low speed.
Old 08-03-2012, 08:57 PM
bluebee's Avatar
For the crosslinked record, QSilver7 posted some nice aux fan information over here today:
-> E39 (1997 - 2003) > please explain!!!
Originally Posted by QSilver7 View Post
It depends on which engine you have...in your case...it's the M52TU...
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders.
See also: E39 Bestlinks & How to easily find what you need, in seconds!
Old 11-18-2012, 10:24 PM
akillies akillies is offline
99 540i Make Over
Mein Auto: 99 540i
I'm having a problem with my aux fan too. My aux turns on and goes off but when it kicks on it makes a very loud noise and sounds like it is straining and the car doesn't over heat. Does anyone have any idea what it could be or what I should do???
Old 11-20-2012, 09:00 AM
Dking078's Avatar
Dking078 Dking078 is offline
Nor genius Nor ignorant
Mein Auto: 2003 BMW 540i
Mine did that just before it died, mine would turn on, but would stay on the highest fan speed setting. Sounds ridiculously loud right? The cheapest OEM fan i've found is from ecstuning, or just get a used one for cheap.
~The Fun Cars~
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [DSP] [AUX] [ICE V5] [BSWs] [DINAN Trans] [M Audio Subs] [E38 lighted int. door handles] [E46 Paddleshifters] [Two-tone Interior]
2008 BMW 550i [Jet Black / Black]
[Sport] [Paddles] [Comfort Access] [IPOD] [Shades] [Nav] [PDC]
A 5'er that was almost too good to be true.
Stuff For Sale:
OEM E39 Nokia Subwoofer [click]
Old 11-20-2012, 02:56 PM
99 540i Make Over
Mein Auto: 99 540i
Ok, can I replace the motor itself to maybe save some money??
Old 04-15-2013, 04:05 AM
bluebee's Avatar
For the crosslinked record, JimLev offers good advice here for discerning aux fan types:
Did your fan motor look like this with these color wires coming out of it?
If so, you have a PWM fan.
The older fans are 3 speed that only have 2 wires ans use relays and resistors to switch speeds.
The resistors are mounted to the fan frame.
See also:
- DIY for how to replace the auxiliary fan (1) (2) (3) & how to test the cooling system auxiliary electrical fan (1) (2) & the infamous fuse 75 (1) & the aux fan relay (1) & an exploding aux fan noise situation (1)
