7 Series DIY
Do It Yourself forum dedicated for 7 Series BMW Owners |
DIY - Keyfob repair
Hi All,
I had a problem with my spare keyfob not working. it would open the doors but not lock them. I know that this is a symptom of a flat battery in the fob and you need to put it in the car to charge up. Well I had it in the car for approx 5 hours and it made no difference. I thought it must be the battery that's dead. therefore open it up and replace the rechargeable battery... so here goes. Cut around the key with a sharp craft knife. (this took about 10-15 mins) ![]() By richpu at 2010-08-30 Once I cut around the keyfob case and opened it up, it became clear why the locking was not working. The switch had come unsoldered. ![]() ![]() detail of the rechargeable battery ![]() Re-soldered the switch and tested it and the car locked and unlocked just fine. so that saved me having a mess around with the battery. ![]() Once I was happy it was working I glued and held it together using cable ties until the glue dried. Hopes this helps anyone if they have the same issue. Regards, RichPu |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
