Old 08-31-2010, 01:13 PM
rrb rrb is offline
Mein Auto: 745LI
Cool 04 745Li - White smoke
Trying to figure this out...Service light,then Emission Related..When the car is on an sits for 3-5min it starts spitting out tons of white smoke..Don't know if its build up in cats from the fuel cleaning, or if cats need to be replaced, or possibly worse than what I'm thinking.. Could really use some insight..Please
Old 08-31-2010, 06:28 PM
USALEXUSBMW750's Avatar
USALEXUSBMW750 USALEXUSBMW750 is offline
Little Odessa
Mein Auto: bmw
its looks like your head gasket blown. do you have a low antifreeze warning?
Old 09-01-2010, 10:59 AM
rrb rrb is offline
Mein Auto: 745LI
no just emission fault code and its code states converter issue
Old 09-01-2010, 09:24 PM
momo_oo[][]oo's Avatar
momo_oo[][]oo momo_oo[][]oo is offline
Mein Auto: M35
+1 on the head gasket.
03 GSX-R 1000
06 Infiniti M35
00 E46 323I SOLD
08 Jeep Grand Cherokee Laredo SOLD
08 E60 535I LEASE OVER
02 E66 745LI LEMON
98 E39 528I SOLD
91 E30 316I SOLD
Old 09-01-2010, 09:42 PM
klob25 klob25 is offline
Mein Auto: 735i
Smile hope this helps
Check this out before you repalce the head gasket !
http://www.bimmerfest.com/forums/sho....php?p=5055784
Old 09-03-2010, 02:35 AM
7_up's Avatar
7_up 7_up is offline
Mein Auto: 745 Li
+2 on the head gasket When theres water in the system white smoke appears from the exhaust.
Old 09-05-2010, 05:30 PM
Mein Auto: 735i
Smile
I dont think it the head gasket as the white smoke will be pouring out all the time.
it only happens after 2 minutes on idle.
http://www.bimmerfest.com/forums/sho...d.php?t=312902
Check this out for some help.
Old 09-13-2010, 03:46 AM
Mein Auto: 735i
Hey all,
They may work and it may not work for everyone. Did an oil change and added in Liqui-Moly Engine Oil Resealer. The white smoke has stop after 3 minutes of idle. I would not put anything else in the oil normally, but a friend said this stuff really works so try it before u pull apart your engine. Give it a try and make u do an oil change at the same time. Hope this helps
Did an oil change.
Put some liquid moly -
