Old 09-03-2010, 04:08 PM
Palantirion's Avatar
Palantirion Palantirion is offline
Z4 Mvangelist
Mein Auto: 2003 M5-S2, 2002 540iT-S2
Thermostat question
I have been told by ESS that at least one of their F/A Z4 M customers has had luck reducing his on-track operating temperatures by replacing the stock thermostat with a 55C thermostat. I do not understand why this would have a beneficial effect. All the thermostat does is regulate when the cooling path is opened. So if you open it earlier, it starts cooling sooner. But if your cooling system isn't sufficient your car would still overheat under track conditions - only slightly later in a session. Also, wouldn't running cooler temps on the street make it harder to pass smog?
What am I missing?
Old 09-03-2010, 05:09 PM
dwm's Avatar
dwm dwm is offline
Send a message via AIM to dwm Send a message via Yahoo to dwm
Mein Auto: 2002 M roadster
I believe the 55C thermostat he/she is talking about is a Motorsport part with better flow characteristics when it's wide open. Or perhaps the thermostat that was replaced wasn't fully opening.
Daniel
2002 M roadster
Old 09-08-2010, 11:03 AM
Z4 Mvangelist
-Thanks for the suggestion, that's something I hadn't thought of.
I've done some research, and according to my motorsport contacts it simply opens earlier than the stock thermostat. So we're just going to install the oil diverter valve and see how that works.
Old 09-08-2010, 11:19 AM
Drivewfo Drivewfo is offline
Enthusiast
Send a message via AIM to Drivewfo
Mein Auto: 2008 Z4 3.0si Roadster
Drill a small hole in the flange of your thermostat. That will help any trapped air escape.
BMWCCA Member
2008 Alpine White Z4 3.0si Roadster 6spd
2006 Silverstone II M5 SMG (gone)
2002 Alpine White 325i Steptronic (gone)
Old 09-08-2010, 11:24 AM
Z4 Mvangelist
-An interesting idea. Does this advice come from theory or personal experience? And do you have any pics?
Old 09-08-2010, 08:32 PM
Enthusiast
I've always done that on my engine builds for my drag car. I used an 1/8" bit and just picked a spot on the flat flange area. Doing that plus jacking up the front of the car such that the radiator filler neck is the highest point of the cooling system (remove cap and let the engine run a few minutes) gets all the air out of the system.
Here's an example pic I found on Google showing the drilled thermostat on a small block chevy:
BMWCCA Member
