E36 (1991 - 1999)
Old 09-04-2010, 03:23 AM
KcChiefs KcChiefs is offline
Mein Auto: 1993 325i
1993 325i no spark no fuel
Checked voltage at the pump and showed 6 volts. Bypassed the fuel pump relay on pins 30 and 87 on the power box and the pump was a humming. Checked all the grounds and they were good. Checked the fusible link in the trunk and that was still intact. Bought a crank position sensor from autozone. Checked the Ohms (590) about the same as my old one, but installed it anyways due to the success others were having on the forum. Still nothing. NO fuel and No spark, just cranks.
No check engine light when I turn to the on position and the start position. Also no CEL when I do the instrument panel test. Pulled the DME out and checked the resistance on all the grounds pin 15 was showing a 2.76 ohms. Couldn't find that ground point via bentley manual or the 93 325I Electrical Troubleshooting guide so I traced the ground about six inches from the DME harness and spliced into it and grounded to the main ground on the front strut location. Checked the resistance on pin 15 and it showed 0.00. Had my fingers crossed and tried to jump start and the same symptoms. Just to be thorough sprayed starter fluid in air box hole and nothing. 4 of the six spark plugs when pulled had oil on the threads, would that shut off the fuel injectors? and/or the fuel pump? Seemed like the prior owner was trying to troubleshoot the issue, a lot of loose trim around dash and trim boards ( seems like they were tracing grounds and other wires). Called the $tealership and they confirmed there shouldn't be an immobilizer installed and thought there was an electrical issue and wanted me to tow it to them to look at. I am currently wait on a valve cover gasket w/ plug seals and a new Fuel Pump relay and Main (DME) relay. Running out of ideas, Any thoughts or tips in a different direction would be appreciated
Old 10-05-2010, 07:51 PM
es1758 es1758 is offline
Mein Auto: e36 525i
Did you ever figure anything out on this? I got a 95 525i with the same issues.
Old 10-05-2010, 07:57 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Wait a tick. Do you have an E36 or a 525i or both? They are mutually exclusive y'know.
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 10-07-2010, 08:13 AM
NMSDAD1 NMSDAD1 is offline
BMW Junkie
Mein Auto: 96 328I 99 328I
Is the main relay comming on?
The DME will not turn on the relay unless there is a signal from the crank position sensor.
Check the resistance ot the sensor. Its a pain in the ass to ge to the plug!!
Old 01-19-2011, 01:55 PM
justinvivod justinvivod is offline
Mein Auto: 93 325i
Question
I'm having the exact same problem with my 93 325i. have you fixed the problem yet?
Old 01-19-2011, 06:43 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
welcome to the 'fest, and this is a old post. (looks like someone was using the search function...)
this is also a very valid reason for 'closure' on threads, to assit in possible future inquiries.
to the op, though, i would check for power to your pump first. then spark.
df
Old 01-19-2011, 09:33 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
This E39 diagnostic thread may also be of assistance for the E36:
- How to diagnose a BMW E39 engine misfire (1) & a cold-engine intermittent misfire (1)
I'm trying to find all the misfire-related threads with closure to add to that diagnostic tree to help others - which is how I ran into this thread.
Alas ... no closure ... no benefit to others.
Old 04-28-2014, 01:33 PM
rodspor rodspor is offline
Mein Auto: work
I am having an electrical proem I have checked all fuses and relays If I put my hand on the throttle body I feel like something is going through this is with the ignition in e off position any ideas would be greatly appreciated this s draining all the juice from my battery forgot 95 325i thank you
Old 04-28-2014, 05:54 PM
Mein Auto: 93 325i
Get a stethoscope and pinpoint the
exact location of the sound.
Do you have cruise control?
It may be sticking on. I've seen it before .
Most everything else in that area is
controlled by the ECU via cam and crank sensor only
During cranking after the initial prime.
When you find the noise check that the
on/off for cruise control switch isn't stuck open.
It might have a relay stuck open.
Old 04-28-2014, 06:53 PM
Mein Auto: 93 325i
Talking Bad ECU
It ended up being a bad ECU.
