Old 09-05-2010, 05:47 PM
dets dets is offline
Mein Auto: 2003 E65 745i
front bumper removal e65 745i
hey guys,
i need to remove my headlights ao i was wondering if any of yall had a dyi about taking the front bumper of an e65 745i. let me know , thanks
dets
2003 BMW 7 Series
-20" M-Series Rims
Old 09-05-2010, 05:59 PM
klob25 klob25 is offline
Mein Auto: 735i
Smile
Originally Posted by dets View Post
hey guys,
dets
Is this to replace a blown parking light ? if so you dont need to remove the headlight..
http://forums.bimmerforums.com/forum...d.php?t=954644
this is almost like the e65 just a couple mroe screws. also remeber to disconnect the frog lamps as you dont want to rip them out.
Old 09-05-2010, 09:32 PM
Keif Keif is offline
Master Tinkerer
Mein Auto: 2007 Alpina B7
My bumper drop removal pictures --> here. It's quite easy.
Black 2007 Alpina B7
Tension strut bushings
White 2007 Alpina B7
Supercharger clutch/bearings, replaced exhaust valve/pulled head, sunroof seal, 6000K angel eyes
Black 2002 BMW 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator & mounting bracket gasket, sunroof seal, CCVs, plugs, sway bar bushings, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, sanded headlights...
Old 08-01-2014, 10:08 AM
msantosm msantosm is offline
Mein Auto: 730d
Unfortunately mine was smashed by some driver that hit me and run away. Can someone tell me where can I find a reasonably priced front bumper for my 730d? I don't mind if it is used (if it is in dark blue and good condition even better). Thanks in advance guys.
Old 11-13-2016, 03:57 PM
fratan fratan is offline
Mein Auto: 2006 750i
Great pictures of the bumper molding removal from Keif. This was my first attempt removing the front bumber of a 2004 745I and I'm glad I had Keif's pictures. I replaced the drivers side headlight assembly and was able to only pull have the molding and then pull half of the bumper out to slid the headlight assembley in. Just make sure you get all the screws because there are many. The tools used were as follows: 8mm socket with a 6 inch extension 3/8", a T15 20 30 with a 1/2inch rachet and screwdriver. A big screwdriver with cloth to pop the molding and patience.
It took me 2 hours on a Saturday and 1 hour on Sunday morning.
2006 750 I
