Old 09-07-2010, 10:50 AM
solefood21 solefood21 is offline
Out Of Control
Mein Auto: 2004 745Li
Vibration on 22s-Pulling my hair out
Alright guys, I have an issue that I can't figure out. My shakes like a Parkinson's patient when I've got my 22s on it. I have Lexani LSS-10 22x9.5 and 22x10.5 with Nexen 3000 (Lexani) 265/30/22 and 295/25/22 tires. None of the wheels are bent and the tread is excellent with no un-even wear, cupping, etc... The set has been rebalanced 5 times by different tire stores with no results. I can slap my OEM wheels back on and they ride true and straight with no vibrations and the tires are pretty shot... BTW, everything is torqued to spec.
Any suggestions of where to start? What is the likelihood that the tires are out of round?
2004 745Li Blk/Blk Lexani/Collectizone
2000 Chevy Tahoe Blk/Custom Foose, Alpine, JBL, laying frame on 24s
2006 HD Street Glide Viper Green PM, Kenwood, Arnott, etc...
1969 Cadillac Coupe DeVille Convertible Blue/Blue/White
Old 09-07-2010, 11:01 AM
GrantWC GrantWC is offline
Mein Auto: 2006 750i
Best guess would be thrust rod bushings. If the vibration is the worst at 60-70 MPH I would almost guarantee that they are the problem. Dealer just replaced mine under warranty, and it solved the same problem.
'06 750i Sport Package. Jet black on Creme/Black, XIX 22" wheels.
'06 Lexus GS430. Glacier Frost Mica on Grey/Black.
'05 F150.
Old 09-07-2010, 11:51 AM
1bad540's Avatar
1bad540 1bad540 is offline
I would have the wheels balanced by road force, its the only way to do 22's. If that doesnt work they are bent or out of round.
[SIGPIC]
99 540i sport, acs type 2's chrome, acs spler pdls,Euroclrs
04 745i aw sport,21's aib's acspedals& rf splr(sold)
00 328i Prem Aw18" 335spt whls(sold)
02 Corvette 6sp,z51,2"drp,19"ccw'sshrt shft,corsa exh,dd nav
05 X5 3.0, pana rf,nav,xenon,cldweather, premium.ipod hookup, 20"4.6rims staggered 315rrs.
06 750I aw, sport. chrome21's,acs pdls,acs rfsplr,mtecs,8k hid fogs,Leds.oem ipod&sirius
03 VIPER, forgelinewheels,tune,exhaust,intake.
Old 09-07-2010, 12:02 PM
irokdastar383 irokdastar383 is offline
Account Under Review
Mein Auto: 745li
Did you do an alignment on your car ?
Old 09-07-2010, 02:01 PM
Out Of Control
Been road force balanced 3 times.
Yep. Done that too...
I'm intrigued by the thrust rod bushing idea. Does anyone have any insight?
Old 09-07-2010, 02:19 PM
white75li's Avatar
white75li white75li is offline
Mein Auto: E65,03 cobra
Are the wheels hub centric because you may need centering rings way to check is remove the lugs on the wheel then see if the rim hub is snug with the hub on the car if you can slide the rim up and down you need centering rings
Old 09-07-2010, 03:10 PM
amg142 amg142 is offline
Mein Auto: 750li
this ^^ I replaced everything mentioned above, and in the end it turned out i needed rings. I never looked into it b/c my wheels are hub centric however the bore was slightly off. stock hub 72.6 my wheel bore is 74
hope this works for you
Old 09-07-2010, 03:37 PM
sanhonda22's Avatar
sanhonda22 sanhonda22 is offline
Sleek Sam
Mein Auto: AC Schnitzer 745Li
A few things to check
- Center Bore of the wheels. May need hub centering rings.
- Do you have the proper lug bolts for the 22s?
- Suspension components. Is something worn out? Such as a bushing or ball joint?
- Are the wheels or tires out of round?
- Are the brake rotors either warped, or unbalanced?
SOLD
2003 745Li
Authentic AC Schnitzer Aero Kit inc Front, Side Skirts, Rear, Mirrors, Roof and Trunk Spoilers
Gloss Black Grille and Window Trim
KW Variant 3 Coilovers
22" Interad Turismo Forged 3-piece wheels
Old 09-07-2010, 03:39 PM
Seven11's Avatar
Seven11 Seven11 is offline
President
Mein Auto: BMW
the wheels can be out of round and still balance out
had that happen to my cousins e55... the wheel would balance out but they were an eggshape
'03 745i - modded - GONE -
Old 09-07-2010, 03:44 PM
Kurikurd85 Kurikurd85 is offline
Mein Auto: 2003 BMW 745li
My 745li never stoped vibrating with 22s on it , I just got tired of trying , I put oem back on have had no issues , all vibration went away , 22s just doesn't work on most 7 , if u want the look , them u gona have vibration , u want comfort , go back to oem . Good luck
Old 09-07-2010, 03:50 PM
Seven11's Avatar
President
Mein Auto: BMW
i have ZERO vibrations... NONE.
and i am on 22s
Old 09-07-2010, 04:00 PM
sanhonda22's Avatar
Sleek Sam
and i am on 22s
Same here. Zero vibrations.
SOLD
2003 745Li
Old 09-07-2010, 04:01 PM
sanhonda22's Avatar
Sleek Sam
Yes, on a regular balancer, you can still get bent wheels to balance to zero. However, on a Roadforce, it would still have balanced out, but it would have told you the wheels out of wack.
SOLD
2003 745Li
Old 09-07-2010, 04:19 PM
jgriffith007's Avatar
jgriffith007 jgriffith007 is online now
Mein Auto: 2009 750 Li
I had some but they werent balanced. I have yet to have any issues with mine as of yet with vibrations
Old 09-07-2010, 09:53 PM
lkapimp216 lkapimp216 is offline
Mein Auto: 750i
I guy on the lexus forum said he had a set of Asantis that were made out of round and would do the exact same thing as you described, I also have a set of 8000$ set of Asantis that the paint peeled off of within 4 months Im still waiting to see if they re going to repaint them I was told by Asanti there is no warranty on paint work, however the shop i deal with is trying to pull some strings, point is Lexani/Asanti are both garbage and their customer service is too!
Old 09-08-2010, 05:38 AM
1bad540's Avatar
My 21's are smooth as silk.
[SIGPIC]
Old 09-08-2010, 05:56 AM
white75li's Avatar
If wheels have been road force balanced any bend or if the rim is out of round would have already been found by the machine.
Old 09-08-2010, 06:38 AM
klob25 klob25 is offline
Mein Auto: 735i
Don't know much about the rims but looks sounds like to be u need to get hubcentric rings. If your thread is good, everything is balance your old rims don't cause the problem then u may need some hubcentric rings. Tell your tyres techo this and If he good he should be able to solve the problem.
Old 09-08-2010, 07:45 PM
Out Of Control
Should have thought of this from day one. Was a manager at a tire shop once upon a time...
Ordered today
Yep.
Everything looks great.
Balanced (and road force balanced 4 times recently...)
Stops like a charm from any speed with any wheel on.
I disagree. I have aftermarket wheels on EVERYTHING that I own. Always have. I've had 24's with a rubberband tire ride smooth as glass. I just know that there's something else that I'm missing. Trying the hub rings.
I'm not very thrilled with their customer service either. I called today and it sounds like someone in the shop answered. Loud as **** in the background. Someone finally gave me the center bore and I found the center bore of the 7 so rings are next. I'm getting sick of this.
Long story short, I ordered some hub centric rings because my Lexanis are a 74.1mm center and the car is 72.56 center. I'll keep everyone posted on the outcome. If not, I might have a slightly used set of 22s for sale pretty cheap. Only had them 8 months and driven on them for about 2.
Old 09-08-2010, 09:38 PM
Mein Auto: 745li
i got 2 questions
1. how much were those rings u ordered?
2. how much for the wheels?
Old 09-08-2010, 10:03 PM
Mein Auto: 735i
i got 2 questions
Hey Mate,
I dont know how much they cost the person but just like to add. dont go cheap on the rings -(spacers).
Cheap ones can break under the torque going to the wheels. Get ones that come from a company that been making them for a while.
I can make you a set of spacers out of iron for 20 bucks. Scape metal, grinder and a drill. .
Old 09-08-2010, 11:53 PM
sanhonda22's Avatar
Sleek Sam
Originally Posted by klob25 View Post
Hey Mate,
I dont think you understand what a hub centering ring is.
SOLD
2003 745Li
Old 09-08-2010, 11:58 PM
Mein Auto: 735i
Maybe : but I bet it it will fix the problem
I guess I got lucky
Old 09-09-2010, 01:20 AM
Seven11's Avatar
President
Mein Auto: BMW
I guess I got lucky
Old 09-09-2010, 05:45 AM
DLF750 DLF750 is offline
Mein Auto: 2006 BMW 750i
Same issue here at one point, got them road force balanced and the vibes went away, Have to do it again now - just got two new tires put on, thought they were balanced but probably not. I am getting it at 60mph again.
2006 BMW 750i, all options except rear entertainment, Monaco Blue/Creme Interior, iPhone cradle, roof spoiler, trunk lip spoiler, license plate delete, 21" Style 128 Wheels/Hankooks, ACS pedals, eBay ACS roof spoiler, Genuine ACS trunk spoiler, BMW iPod integration and Sirius Radio dealer installed, Angel Eyes MTech V3 and fogs to match. Planned mods :tints SOLD
