Old 09-08-2010, 05:34 AM
Caicedo.salomon Caicedo.salomon is offline
Mein Auto: 2008 BMW 328i
Changing water pump and timing belt
I want to change my water pump and timing belt. I just need help with where I should get the parts. And exactly a list of all the parts and tools I need for the job. Also any tips on things I should also change while doing this job. Please help. Thank you.
Old 09-08-2010, 05:58 AM
ncmallard78's Avatar
ncmallard78 ncmallard78 is offline
Mein Auto: BMW 2003 540i m-sport
I bought my parts through autohaus.az. Everyone will tell you to do the whole coolant overhaul including radiator, thermostat, fan, fan clutch etc. I did this and all the parts ammounted to 550 plus 400 in indie labor.
Old 09-08-2010, 06:21 AM
cn90 cn90 is offline
Most BMWs run on Timing Chain (not Timing Belt).
Search forum for tons of info on cooling system.
Old 09-08-2010, 06:33 AM
I have a e39 (2000 528i)
Old 09-08-2010, 09:32 AM
speedgoat speedgoat is offline
Mein Auto: 2002 540iA
Your 528i does not have a timing belt, it has a timing chain and should last for the life of the engine.
Old 09-08-2010, 11:45 AM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
You'll need two special tools (see links below) to remove the fan clutch nut.
Cooling system overhaul DIYs:
- Pictorial look at typical E39 cooling system failure modes (1)
- Cooling system recommended parts list (1)
- Coolants recommended by BMW and users (1)
- Bleeding the cooling system (1) (2) (3)
- How to refill M52/M54 coolant DIY (cn90)
- Cooling system DIY (aioros 1999-2003 M54) (cn90 1997-1998 M54TU) (pelican 3-series)
- E39 Fan shroud removal DIY (Besian) (M54)
- Tools necessary for a cooling system overhaul
- Cooling system overhaul tips (fan clutch nut removal) (fan clutch nut replace) (hose removal) (o-ring replace)
- Cooling system overhaul common mishaps (broken nipple) (crooked fan clutch nut) (bleeder screw)
- Zionsville replacement cooling system (BlackBMWs) (William) (ohmess)
- Expansion tank floating mechanical coolant level sensor height (1) (2)
- High instrument cluster check of the cooling system temperature KTMP (1)
- Cooling system date stickers (1) (2)
- What brand of waterpump to buy (1)
- Fan clutch failure modes (1)
- Modifying the cooling system (pressure cap) (zero psi fluids)
Old 09-08-2010, 02:00 PM
poolman poolman is offline
Mein Auto: 525i station wagon
While your doing the cooling system--change out your Vanos seals--that will bring your timing back into the spec's from the factory--do a search for Besian Systems
Old 09-09-2010, 01:07 PM
So I should just do the water pump and disregard changing the timing chain
Old 09-09-2010, 01:42 PM
bmw_n00b13's Avatar
bmw_n00b13 bmw_n00b13 is offline
Freude am Fahren
Mein Auto: 99 528iA
Yes, but do the VANOS too. http://www.bimmerfest.com/forums/sho...d.php?t=379225
'99 528i ('98/12 build). 282,000km BY29428/Royalrot
Breaking My Wallet since 2009
Mods: Stoptech SS brake hose, 280piece toolkit resting on trunk floor, Beisan VANOS seals, increasing amounts of duct tape and glue
'99 540i (grandfather's)
Old 09-09-2010, 01:57 PM
mrpumpk1n mrpumpk1n is offline
Mein Auto: 540i 1997
are you sure your not mixing up the timing belt for the serpentine belt?
"Owning any german car is like hanukkah,
every day another light"
Old 09-09-2010, 02:03 PM
zybanuser zybanuser is offline
Mein Auto: 2000 BMW Z3 2.5
That's what I was thinking. OP probably referring to sepentine belt!
If you do the vanos, might as well do the valve cover gasket!
Old 09-09-2010, 02:19 PM
bmw_n00b13's Avatar
Freude am Fahren
Mein Auto: 99 528iA
Good point mrpumpk1n and zybanuser.
On the E39 a water pump replacement is not sufficient to keep the car reliable. You should be looking at replacing at least the belts, radiator, hoses, expansion tanks, and a few other bits at this mileage. A cooling system overhaul!
Old 09-09-2010, 02:50 PM
I have 159,000.
Old 09-09-2010, 02:56 PM
bluebee's Avatar
To the OP, did you mean the belts shown in this picture (of the I6)?
Old 09-09-2010, 03:41 PM
xraye39 xraye39 is offline
Mein Auto: 530i
Sorry but this is simply not the case, the special tools are not required.
I have removed the e39 fan clutch on 3 different cars and only use a 32mm wrench and a small hammer, both of which would not be considered special tools.
Now if you are unable for some reason to remove it then you might consider a getting/making/cobbling together a special tool i.e. "holding tool".
2003 530iA Sport - Titangrau Metallic/Schwarz Montana
Build Codes: ZSP/ZPP/ZCW. Born on date: 09/02, Dingolfing, Deutschland
NAV MKIV | PP | CWP | Xenons | Style 42s | Rear Shades | OEM ULF Bluetooth | Euro Armrest | Beisan Vanos Seals |
2003 530i/5Spd Sport - Titanium Silber/Schwarz Montana
| PP | Xenons | Style 42s | OEM TCU Bluetooth | Euro Armrest | Beisan Vanos Seals |
2001 525iA - Anthracite Metalic / Grau Montana
Sold but in the "family"
Old 09-09-2010, 05:10 PM
dms540i's Avatar
dms540i dms540i is offline
Mein Auto: 1999 BMW 540iA
+1 I know you're getting a lot of do this do that, but if I were you I would do the radiator, expansion tank, and thermostat with the water pump. Serpentine belt too if you see its cracked. That's where I would start.
BMWCCA#401441
Old 09-09-2010, 10:29 PM
bluebee's Avatar
My philosophy is that I'm saving on not paying a mechanic so I can afford to buy the tool that makes the job easier.
There are entire threads on what tools you really need for a cooling system overhaul ... plus a whole bunch of "I can't get my fan clutch nut off" help threads scattered about. Here's one, for example:
You're totally right that it isn't required that you have the special tools; but I have them, and, I would NEVER do the job without them. They made it sooooooooooo easy to get the fan clutch nut off (once I put them on right) that I wouldn't even consider the hammer trick.
There are MANY times where a special tool isn't required ... but the special tool makes the job sooooo much easier ... that it's worth it in the end.
- How to make your own thrust bearing tool
- How to make your own fan clutch nut tools
- How to make your own car ramps
- How to make your own subframe and differential bushings tool
- How to make your own oxygen sensor tool
- How to make your own VANOS solenoid socket tool
etc.
Old 09-10-2010, 02:23 PM
Mein Auto: 530i
I am not paying a mechanic either and money is not an issue for me, if I need somthing I buy it, however there is no value in buying things I don't need.
Now do some folks need the tool, sure, I have been reading their posts for years and I have no idea why they can't get the darn fan clutch off.
I have taken the fan off 3 different E39s and each time it comes off as easy as pie without having a "special" tool. A simple carefully placed tap with a hammer on my 32mm wrench and voila done.
Not trying to nitpick but to say the special tool is required is not correct, now one might say if you experience difficulty removing the fan then you might want to consider buying the tool.
Old 09-10-2010, 04:18 PM
Orxan4ik's Avatar
Orxan4ik Orxan4ik is offline
Been there done that...
Send a message via ICQ to Orxan4ik Send a message via AIM to Orxan4ik Send a message via MSN to Orxan4ik Send a message via Yahoo to Orxan4ik
Mein Auto: '97 540iA
M52 is aint no VW 1.8T
(oOO\(|||)(|||)/OOo) /00=[][]=00\[/B]
Old 09-10-2010, 04:22 PM
dalekressin's Avatar
dalekressin dalekressin is offline
Mein Auto: 2010 M3
Have everything set up and plan to break the job up ~2days.
Great DIYs here.
94 530i sold (That was difficult for me)
01 530i >144,500+ miles SOLD
06 330XI winter's especially fun drive (SOLD)
10 M3 Sedan (sweet)
13 Nissan GT-R Black Edition
14 Porsche Cayenne Platinum Diesel
15 Porsche GT3
16 Porsche GT4
BMWCCA 4215
Old 09-11-2010, 11:41 PM
bluebee's Avatar
Hi XRaye39,
I'm sorry to imply the water-pump-counterhold tool was required. I should have been clearer. It's optional. A 32mm open-end wrench is required though.
As you said, some people get along just fine without the pulley counterhold tool. For example, in this thread, cn90 uses a simple screwdriver (see pic below).
Others (see this thread), say it's "100%" needed.
Either way, the OP has the information they need to make an informed decision by now.
