Advice needed! 1999 M5 will not start! - Bimmerfest - BMW Forums
Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > E39 M5 (1998-2003)
E39 M5 (1998-2003)
Old 09-08-2010, 07:44 AM
beamer99 beamer99 is offline
Mein Auto: bmw m5
Hi
Has anyone had any experience of their M5 suddenly not start?? The car was fine, drove from work to the shops. Turned off the engine, then upon my return the car wouldn't start! The engine is turning but not firing up. Tried to jump start, no use, just drained battery. Towed it home and charged the battery and it's testing as 12.11 volts at rest.
Had a diagnostic guy come out and he eliminated any fuel problems. Faults that came up showed ignition faults. We stripped the engine to check the injectors and fuel is ok, but we have found no spark.
Have now been told it 'could be the ECU' gonna cost best part of 1400! But not actually confirmed.
Does anyone know if it could be anything else?? I have looked on the forum to see if anyone has had similar problems but cannot find anything specific.
HELP! Clutching at straws before having to shell out that sort of money.
Old 09-08-2010, 12:49 PM
03BeastCharmer's Avatar
03BeastCharmer 03BeastCharmer is offline
Mein Auto: 03 M5; 97 M3
When you tried to turn it over did it do it with full strength? If not it might still be the battery. Without a fully charged battery, these cars don't like to start. Besides that, I don't have any good ideas about what it could be.
The Beast: E39 Dinan M5 (Gone)
Beast 2.0: E92 M3
"Control, Vision, Determination" These are the three fundamental components of the new generation race car driver!! SPEED is a by-product! -Memphis Raines
Old 09-08-2010, 11:02 PM
Mein Auto: bmw m5
Hi
It seemed to do it will full strength. My insticnt has been telling me it's possibly the battery. I'm going to take it to be tested, because when I had it on charge for a whole day and half the tester still didn't state fully charged but voltage was above 13v.
Thanks, for reply. Glad to see another opinion on possible battery problem.
Old 09-09-2010, 02:17 PM
PHOENIXCOUPE PHOENIXCOUPE is offline
Mein Auto: mcoupe
One thing I recommend you check is the ews antenna ring and the ews control unit. Ring antenna runs about 14dollars and the ews mod runs around 150.00
