Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 3 Series / 4 Series > E30 (1982 - 1993)
E30 (1982 - 1993)
Old 09-10-2010, 06:37 PM
JPADGUY JPADGUY is offline
Mein Auto: 2003 black 530 sport M
Question 1985 318 Back up lights switch
Back up lights will not come on. All fuses and bulbs good. Does anyone know where the switch is accessed from?
Old 09-10-2010, 07:13 PM
downhiller's Avatar
livin large
underneathe the center console. i think if you just remove the shifter boot its somewhat right there. and thats on the 5spd
Old 09-11-2010, 12:11 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
^not in my experience.. has been on the side of the gearbox only acessable from underneath the car on the right hand side (could be left though). This is on ZF4HP22 and Getrag240 gearboxes anyway
Old 09-11-2010, 06:44 AM
downhiller's Avatar
livin large
you sure? i thought mine was right on top of the tranny tunnel by the shifter bushing.........of course im going off something i never messed with either
Old 09-11-2010, 08:04 AM
ForcedFirebird's Avatar
ForcedFirebird ForcedFirebird is offline
Mein Auto: 1986 327is
I have not experienced the 240 gearbox, but that's what's in the OP's car. 85 and later car's got the Getrag 260
Old 09-11-2010, 12:16 PM
03bmw525i 03bmw525i is offline
Mein Auto: 03 525iA, '87 325e 5spd
Manual transmissions have the reverse light switch underneath the car on the tranny case on the passenger side, accessible from underneath car. On automatic transmissions, the switch is near/underneath the shift, accessible from inside the car.
Old 09-16-2010, 06:07 PM
obenski obenski is offline
Mein Auto: 1986 BMW 325
I have 1987 325 and it looks the same problem for back up lights. It will work only if you shake the stick whilst on the reverse mode. the light will come on.
Old 09-18-2010, 11:36 AM
Krumchev2's Avatar
Krumchev2 Krumchev2 is offline
Straight Bimmin
Mein Auto: 91' 318ic
The question now is does he have a 5 speed or auto?
Old 08-01-2012, 04:19 PM
enyong112 enyong112 is offline
Mein Auto: 318i
reviving this thread... I have the same problem (no lights on reverse) ... bulbs and fuses are all ok... Mine is a 5-speed manual... need help can pass state inspection w/o the light i think...
Old 08-01-2012, 07:28 PM
shima14 shima14 is offline
Mein Auto: 86 325e
On top of the transmission there's 2 wires that go to a reverse switch change that n should fix it... Should make sure getting power to it first though but that was my problem
Old 08-02-2012, 02:33 AM
Originally Posted by 03bmw525i View Post
Manual transmissions have the reverse light switch underneath the car on the tranny case on the left side, accessible from underneath car. On automatic transmissions, the switch is near/underneath the shift, accessible from inside the car.
quoted for 100% truth, only tickled for a global audience. i hate the words passengers-side and drivers-side. This applies for all E30 getrag manuals and ZF autos. ZF manuals may be different
Old 08-02-2012, 03:00 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Talking
The civilised world has the steering wheel on the RIGHT side
Nuff said
Don't take life too seriously; no one gets out alive !
Old 08-02-2012, 04:43 AM
Japan and the UK not civilised huh?
Old 08-02-2012, 05:01 AM
Nick323's Avatar
Nick's Toys
Cool
The last time I drove in the UK, Australia, Japan, New Zealand & almost all of Africa I was sitting on the right hand side...
Been out in the pub eh Cobber
Old 08-02-2012, 11:01 PM
just a few at home, sorry, must have misread it, was 20 minutes before midnight too, sleep probably had set in.
Old 08-04-2012, 09:52 AM
Nick323's Avatar
Nick's Toys
Wink Drinkin at home
Old 08-04-2012, 12:11 PM
1991318i 1991318i is offline
Mein Auto: BMW E30 0011-0001-1000
the actual switch for it is on the trans somewhere, the connector for it is under the lower center console between the shift boot and the ash tray
dat E30
Old 09-03-2012, 04:48 AM
15Michaeljoseph 15Michaeljoseph is offline
Mein Auto: 1987 325is
I'm having this same problem with my 87 325is! guys, where is the switch actually? side of tranny, or underneath the shift boot? is there any way to fix this without dropping the tranny? Thats way too big a job for me...
Old 09-03-2012, 07:27 AM
you need to get to both places if your're gonna replace it.
the actual switch is on the side of the tranny.
the connector from the switch to the wiring in the car should be somewhere under the lower center console under the shift boot.
dat E30
Old 09-03-2012, 02:24 PM
yup
Old 09-03-2012, 08:37 PM
Mein Auto: 86 325e
Underneath shift boot there's a 2 wire connector that runs on top of the transmission to the reverse switch... I've had to replace the switch and those wires takes alot of patience but there's no need to pull the transmission
Old 09-03-2012, 10:03 PM
it shouldn't take that much patience. it took me like 5 minutes to do only because i accidentally grabbed the wrong size socket.
just grab a wire hanger that you dont care much about and feed it down
dat E30
Old 09-04-2012, 02:07 AM
Mein Auto: 86 325e
I'm talking bout the reverse switch if needing replacement.. Yes wires are easy to replace
Old 09-04-2012, 09:47 AM
yea... thats what im talking about
dat E30
