E36 (1991 - 1999)
Old 09-11-2010, 08:09 PM
rooster1986's Avatar
rooster1986 rooster1986 is offline
Mein Auto: 92 325i
Gear Set Replacement
I really want a different gear set in my differential, 3.15 isn't cutting it for me. So I plan on getting either the 3.23 or 3.46. I know the pros and cons of changing the gearing but my question is how hard is it to swap the gearing? Will I need to worry about extremely tight clearences or is it a simple swap? I found LSD clutch packs for $195 and the gear set for $175. Added up it will be cheaper than buying a used LSD with 3.23 or 3.46.
Old 09-11-2010, 08:39 PM
3B2M8WI 3B2M8WI is offline
Mein Auto: 1998 BMW 328i - Avus blue
im sorry just a quick question since we are on the topic of LSD's can you get an LSD for an auto trans?
Old 09-11-2010, 08:51 PM
Mein Auto: 92 325i
As far as I know, the tranny and differential are two different things. Im not totaly sure but you should be able to just swap diffs or the LSD guts into your existing differential.
Old 09-11-2010, 08:52 PM
ZeGerman's Avatar
ZeGerman ZeGerman is online now
Warm Leatherette
Mein Auto: 1998 BMW 328is
Yes, you can have an LSD mated to an auto transmission.
Also, it is much less labor intensive to swap the entire final drive unit, rather than just the internals.
1998 BMW 328is
1966 Pontiac GTO
Old 09-11-2010, 09:03 PM
Mein Auto: 92 325i
Thats what I was affraid of. I was just looking at the cheapest of the options. Would it take more than a day to swap the gear set?
Old 09-11-2010, 09:17 PM
ZeGerman's Avatar
Warm Leatherette
Depends on your skill level, tools, etc. I'd just save your money for a few more pay cycles and do it the easy way.
1998 BMW 328is
1966 Pontiac GTO
Old 09-11-2010, 10:05 PM
hornhospital's Avatar
hornhospital hornhospital is online now
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
^ +1 Differential rebuilding/changing is tedious, precise work, requires tools that most DIYers don't have, and if you do it wrong the diff doesn't last very long. Sell your open diff and buy an LSD when you can afford it. MUCH easier and just about fool-proof.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
