E34 (1989 - 1995)
Old 09-21-2010, 07:01 PM
Monsignor's Avatar
Monsignor Monsignor is offline
BMW CCA Memeber #445389
Mein Auto: Sig
Dunno if these are your style but check 'em out. the E60s have the same exact wheel specs as E34s
http://www.bimmerfest.com/forums/sho...d.php?t=485994
Better than those godawful 20s at least.
And if its too far away from you, I can middleman it...
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 10-01-2010, 10:31 PM
TommyD525i TommyD525i is offline
Mein Auto: 1992 525Ii
Hey bud. The shimmy could be coming from the wheels or tires. Have you checked their balance lately? You could have thrown a weight. Start there.
If they are balanced then:
Mine did the exact same thing. I replaced both the upper and lower control arms(trust arm) on both sides, sway bar links, tie rods and the problem mellowed. But wasn't fix! I then did a complete brake job including new slotted rotors and Bavauto Rigid Red pads, and SS brake lines. Problem solved! The problem was in my rotors. But I am happy that I did the suspension to because it rides like a new car again.
I use to have 17's(crappy ride and heavier) on it but now I run stock rims(15's) with 225's up front and 235's in the rear. And it's WAAAY smooth and handles great.
One of the things one must consider when going up in rim size is that larger rims WILL weigh more, which will effect performance. This is unless you are willing fork over lots of $$$$. It's all a matter of taste though, performance is expensive and you can always buy "bling" for cheap if your will to sacrifice performance. Mixing both performance with looks is obviously the most expensive though.
Also remember that when you go up in wheel size, more of the brakes are visible! Make sure they look sick too! I would take the $500 and find someone who is parting out a 540 or M5 and buy the brakes off that and rebuild um. Just my opinion though.
Good luck and welcome!
