The X5 SAV Forum
Old 09-10-2010, 05:30 AM
WVMTNBIKER WVMTNBIKER is offline
Mein Auto: 2003 X5 3.0i
No heat, brrrrrrrrr
My new purchase: 2003 X5 3.0i w/dual climate control, 81K miles. PROBLEM SOLVED. MOVED RED DIAL IN CENTER OF VENTS; NOW HAVE GREAT HEAT. BOY AM I EVER DUMB.
A/C works perfectly. Fan control works perfectly. No weird noises from fan or vents; no wet carpet and coolant level perfect.
Drove to work today at 48 degrees here in WV. Drove 2.0 miles to work w/temp gauge right in the middle/normal operating range. Turned heaters on for both sides--drivers and passenger to 80+ degree. NO heat. Wasn't cold like outside air but for sure NOT warm.
Recirculation button off. Air split between middle and floor.
Ideas? Everything else seems to work fine on the climate control; upper, middle and lower air vents putting out air. A/C has worked flawlessly.
I just don't have any heat. Brrrrrrrr....
HELP!
