7 Series - E23 / E32 (1977 - 1994)
Can put the rims of a 750 on my 740il?
hello can anyone tell me if I can put the rims of a 750 on my 740il?
What years?
Yes
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
yes... with exception of the "X" SUV models all the BMWs have the same bolt pattern. The issue is going to be the size of the tires, as the E65/66 models run a relatively huge tire for a car.
Just because I said it doesn't make it true... it just makes in my opinion. Conversely, just because you said it doesn't make it true, and I'm still going to form my own opinion. |
The "issue" is also the offset.
White 1993 850Ci - 251,187 miles Black 1993 850Ci - 125,508 miles |
But be careful, not all BMWs have the same hub size...
I'm 99% sure you can
Justin '94 530i 5-Speed"I hit the gasser, go faster, all you hear is dual-exhaust flow master." ------------------------------------------------------------------------- All California BMW owners click here for a meet and greet!
Yes
Should work, but as others have mentioned
There are a few things you have to make sure of. Center Hub size for example may be different. On my 07 750 the Hub is 72.6 on a X5 it is 74.1 and like one of the other members mentioned, the offset has to be correct, so that the wheels don't stick out too far or too far in.
Last but not least is the Tire size. Hope this helps |
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
