Old 09-19-2010, 04:39 PM
RusOnline RusOnline is offline
Mein Auto: 2011 BMW 535I
F10 BMW 535I Sport Pkg _____ Tire Advice ____
What's up guy's. I need an advice. I got 2011 BMW 535i Sport pkg which i ve been driving for 3 months now. The car is a dream but the run flats drive me crazy! This is the worst thing that BMW could do! It's not even funny! You just can't relax while driving.
I ve changed front tires 2 times already.
Now i decide to change the whole set of 4 for non run flats Continental Extreme Contact DW Max Performance summer tires for better and more comfortable driving. I spoke with tire rack representative and he told me i have choice of two, front 245/40/19 back 275/35/19 stock size and also i can put front 255/40/19 and rear 285/35/19 which he told me would be more comfortable and softer than the stock size.
Does Anyone have the experience with that size and if the wider tires more comfortable in major?
Old 09-19-2010, 05:05 PM
TJPark01's Avatar
TJPark01 TJPark01 is offline
Mein Auto: E92 335i
Just the fact you are swapping the RFT's to All Seasons is gonna make the car more comfortable. He maybe correct in terms of comfort, as sticking a wider tire on the car with the same aspect ratio is going to yield a taller sidewall, but it may come at a higher penalty in fuel consumption, as there is a point when wider rubber starts hurting your efficiency. I have had 2 nails on the same tire, and although these runflats are better than the bridestones I have encountered, I'm still inclined to swap them out when they wear out. I'm also more inclined to stick with the manufacturers size specs, but that's just me.
Old 09-19-2010, 05:14 PM
The set going to be max summer performance i don't think i would go with all seasons. Thanks for advice!!!
Old 09-19-2010, 06:07 PM
TJPark01's Avatar
Mein Auto: E92 335i
My bad I thought you said Conti DWS. Yeah, I've been looking at the DW's, they seem to be a bit cheaper and get decent reviews. I haven't had real good luck with Conti's, mostly the two that I've encountered had a lot of road noise. I'm leaning towards the Bridgestone Potenza RE050A Pole Position. Either way, I think the ride may be better in these than the good years, due to that stiff sidewall.
Old 09-19-2010, 07:08 PM
dunccfp dunccfp is offline
Mein Auto: F10
I put the Conti Extreme Contact DWS's on my 535i and they are great. I stored 3 of the OEM tires and use 1 as a spare, got a rim from tire rack for $80. I'll return the car with the OEM's The all weather tires are great. Summer tires on a 300 hp car is overkill and not necessary.
I drive aggressively and in fact I drove my car back to back with the demo from my dealer with the rf's and the conti's actually were better. Some think the sidewalls are soft on the conti's = I didn't think so. The conti's are also quieter and last alot longer. They are also top rated for wet and snow. $950 for a set of 4.
Trust me get the all season's. They even come with a 30 money back satisfaction guarantee. No brainer.
Old 09-19-2010, 07:25 PM
Thanks a lot for advice. I'll think about it.
Old 09-19-2010, 08:14 PM
TJPark01's Avatar
Mein Auto: E92 335i
If you're in NYC how are you gonna run the DW's during the winter? Are you gonna run a snow tire during the winter and the DW's the other 3 seasons?
Old 09-19-2010, 09:08 PM
pharding pharding is offline
Mein Auto: 14 550i
BMW is dropping the summer performance tires and going with four season run flats.
04 Successfully lobbied BMW NA and BMW FS to prohibit dealers from using residual values based upon Euro Delivery MSRP and to use US MSRP saving BMW Enthusiasts several thousand dollars on each lease
17 540i in transit
14 550i Euro Del
14 X3 2.8i
11 550i Euro Del, Retired
08 550i Euro Del, Retired
07 330i Retired
06 330i Euro Del, Retired
04 545i Euro Del, Retired
01 530i Euro Del, Retired
Old 09-19-2010, 09:48 PM
I have X5 so it's not a problem.
Old 09-19-2010, 09:50 PM
Temperature does matter for summer tires or it's just a question of snow?
Old 09-19-2010, 10:01 PM
solstice solstice is offline
Mein Auto: 2015 F80 M3
Yes temperature matters as in freezing temperatures. A summer tire gets harder while a winter tires threads remains soft and grippy.
Old 09-20-2010, 08:29 AM
TJPark01's Avatar
Mein Auto: E92 335i
If you mean the Good Year Excellence RFT tires, those are still summer tires, but my understanding is that they are Grand Touring Summer, not Max Performance Summer.
Old 09-20-2010, 09:47 AM
mdspadeccom mdspadeccom is offline
Mein Auto: 2011 535i
I don't understand how replacing RTFs with standard tires works. RTFs have less sidewall compliance that standard tires, and the BMW engineers compensated by adding the compliance into the suspension. That is why the ride is ok with RTFs this year. If you switch to standard tires then there will be double compliance and the ride/handling will get wierd, wouldn't you think?
Old 09-20-2010, 11:10 AM
jimefam jimefam is offline
Mein Auto: 2011 550i on order
If by wierd you mean more comfortable and responsive and less noisy then yes I think so.
Old 09-20-2010, 11:54 AM
2x the compliance engineered in by BMW might actually make it too soft?
Old 09-20-2010, 01:21 PM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i; 428 GC; Twin X1's
Wrong on 2 counts:
  1. The tread compound on the summer tires is optimized for summer temperatures. Even on a dry roadway, their grip will be terrible in the middle of January.
  2. x-Drive will give you improved traction for acceleration, compared to RWD or FWD. It does NOTHING for cornering or braking. Go to any body shop in January and look at the number of SUV's with front end damage. Your summer tires will not stop or corner on snow or ice. All Seasons give you a fighting chance. Dedicated snows are the best solution.
Unless you are going to own your car for less than 2 years, you are going to replace your tires at least once. Why not make one of those sets of tires dedicated winter tires? In most cases, they are less expensive than summer tires, anyway. Swap 'em back and forth every Easter and Thanksgiving. Best of both worlds, huge improvement in safety, at no additional cost.
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 09-20-2010, 01:23 PM
gregb10's Avatar
gregb10 gregb10 is offline
Mein Auto: F10 535ix/E60 2008 535 XI
Originally Posted by quackbury View Post
Wrong on 2 counts:
I agree, im going out of a 08 535xi to a F10 535i,,, will by snow tires.
Old 09-20-2010, 01:45 PM
I can tell you one thing guys, i don't know what bmw engineers ve been doing but f10 bmw on runflats is complete nighmare! I ve had 2002 Mercedes s600 on 19's and now i have 2005 BMW X5 4.8 on 20's and f10 535i. 535i on runflats is the worst case on earth!
You can go to Tire Rck and read some reviews on Good Year Exellence RunOnFlat tires which goes stock on f10. People are not complaining they are crying.
Old 09-20-2010, 02:26 PM
gregb10's Avatar
Crying about what? Harsh ride?
Old 09-20-2010, 02:33 PM
quackbury's Avatar
///Monkeyazz Duck
Nope. Other problems. Here's the link:
http://www.tirerack.com/survey/Surve...irePageLocQty=
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
Old 09-20-2010, 02:44 PM
TJPark01's Avatar
Mein Auto: E92 335i
Seems about average to me. I'm the LA responder by the way.
Old 09-20-2010, 04:02 PM
Mein Auto: F10
In NYC we have 6 days a year where with snows youre a hero. In the dry and rain they blow. All seasons are a better solution.
Old 09-20-2010, 04:05 PM
Mein Auto: F10
No I drove both back to back. Conti dws vs rft. Same cornering. Conti's better in dry, rft's squeeling.
Old 09-20-2010, 08:16 PM
acetner acetner is offline
Mein Auto: 2008 E60
Is the problem with the run flats on the stock wheel, or just the run flats on the sport package?
Old 09-21-2010, 12:03 PM
To be honest i ve never drove on runflats before and never heard about any issues with them nether. I have the experience with run flats that comes stock on sport pkg.
Good Year Exellence RunOnFlat tires.
