Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Cars - Private Party
Do you have a car for sale? Are you looking for a new BMW? Check here daily as well as searching on craigslist and eBay Motors
Old 09-19-2010, 07:25 PM
b franko b franko is offline
Mein Auto: 2002
For Sale-1975-2002
1975 BMW 2002
Mintgrun (mint green)
Manual
4 Cylinder
Moon roof
I am asking $5,200.00 for the car.
I have had the car about 6 years, bought in Minnesota, where it lived ~ 4 years and was kept in a garage and not driven in Winter or in rain; before that it lived in California.
Since it came to Virginia it has been parked under roof throughout the year and not driven in Winter. Spring, Summer and Fall driven 3 to 7 days a week, mostly local except the occasional 3-4 hour trip.
Super solid, good clutch, great little car. Needs a tune up, probably spark plugs.
Mileage unknown Ė odometer broken, engine rebuilt before I owned it.
Just replaced front brakes and front strut mounts, adjusted bearings.
Recaro-style sport seats and Momo steering wheel.
Other upgrades such as Crane XR700 electronic ignition and stainless steel brake lines put in before I owned it.
I also had a limited slip differential put in right when I got it.
It has been lowered and has relatively stiff suspension so cornering is a pleasure.
Rust Ė superficial only, none on actual frame
- mild rust spots on trunk of car
- rust bubble on driver and passenger side front fenders
- small rust cut below window on driver door
- roof of car sanded down and primed due to rust spots, currently primer grey
Small dent on driver door where wind blew door too far open.
Doors donít lock, but had a Clifford alarm with power locks installed, havenít used it as I live in the country and donít need it.
Casing around gear shift loose.
Card board above pedals loose.
Turn signal does not return, has to be done manually.
Defrost works but switch feels loose and does not stay all the way in the Ďoní position.
If interested and in the area come check it out and take it for a drive.
If you want to see more pictures just let me know, I check e-mail 1 time daily so I will get back to you relatively quickly.
You can e-mail me directly at suipaire@gmail.com.
ID:	246856   Click image for larger version
ID:	246857   Click image for larger version
Name:	Int thru window 1.jpg
ID:	246858   Click image for larger version
ID:	246859   Click image for larger version
Name:	Fr rt 1.jpg
Name:	Side rust 2.jpg
1975, 2002, bmw, manual, mintgrun
