Old 09-20-2010, 11:52 AM
attila316 attila316 is offline
Mein Auto: None
Anyone tried putting F10 wheels on E60?
Just wondering if I should get a set of the following for E60 550i.
Front wheels are 19x8.5 et33 offset
Rear wheels are 19x9 et44 offset
Tire sizes are 245/40R19 front and 275/35R19 rear
Old 09-20-2010, 01:17 PM
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
You'll get rubbing cause it'll push the wheel outside by about 15mm to 18mm, Not sure if you can even roll tyhe fender and get away with it (especially when you have full number of passengers).
Old 09-20-2010, 01:28 PM
Mein Auto: None
I though positive offset will push the tires inward not the other way around, am I wrong?
Old 09-20-2010, 01:35 PM
JeffVander JeffVander is offline
Mein Auto: X5 4.8is
Those wheel specs indicate that those wheels may fit on a X-Drive 5-series. However, it would require a physical check to be sure. The X-Drive uses a 43mm offset. However, those tires definitely are too big in circumference.
Old 09-20-2010, 02:23 PM
My bad, yep the F10 wheels on E60 will push the wheels inward by 15mm in the front and 18mm in the rear (also less clearance in the suspension side since they are the same width). So OP will likely get rubbing inside but way enough clearance on the fender side though looks ugly from wheel well gap.
Old 09-20-2010, 02:50 PM
core22 core22 is offline
Send a message via AIM to core22
Mein Auto: F10 M5
XI rears can handle offsets from 33 to 53 without rubbing. Big brake kits may not fit. Can you try before you buy?
M5 (F10) | Alpine White | Black Merino | Fineline Anthracite
640i GC (F06) | M Sport | Sapphire Black | Amaro Brown Merino | Red Sycamore | M Performance Exhaust
535xi (E60) | M Sport | Platinum Gray | Black Dakota | Walnut | Dinan S2 | BMS DCI | KWv3 | Beyern Mesh
525i (E60) | Sapphire Black | Black Dakota | Walnut
Old 09-20-2010, 03:07 PM
OP has E60 550i (so not an Xi car) and my calculation based of going from E60 19" sport wheels which are 9"/18mm and 9.5"/32mm to F10 wheels (listed by OP in terms of spec).
Big brake kit shouldn't be a problem in 19" setup.
Old 09-20-2010, 03:16 PM
Mein Auto: F10 M5
Ahh, you know, I did read that he had a 550 but I had a brain stutter I think
Old 09-20-2010, 10:20 PM
Mein Auto: None
I talked to the seller today and will bring my car in some time and see how it fits. Definitely will need spacers for sure.
Old 09-21-2010, 01:07 PM
Mein Auto: X5 4.8is
If you get spacers, you'll need longer bolts. You'll also want to get high quality spacers or your wheels won't track straight.
Old 09-21-2010, 01:18 PM
Mein Auto: None
I'm thinking ECS spacers if I do go this route. Anyone has suggestions on spacers? I heard about H&R and Also Turner Motorsport also.
