7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code! |
#51
I am sure there are some tuning shop that had dyno facility in your area. and it should not be expensive. You know, just to make sure that you do indeed got your software upgraded to Dinan... |
#52
Thanks for the advice. Only Dyno facility can do this? They are kind of far from where I live.
they will be able to print out your real horsepower reading from your rear. Please note there will be some driveline losses, so if your Dinan quote 500hp, that mean on the dyno, your car should put at least 80% of that or around 400 horsepower. and if the dyno show your car only put around 320 horsepower, that mean your ECU had not been updated with the dinan software and still stocks. Arm with this print out (chart and number for both Horsepower and torque), you can easily argue for refund with your BMW dealer. but if you just came to them and ask for software checking, they could easily say they already did that... or if you go to another BMW dealer and ask for them to scan your ECU, than the first BMW dealer where you install your dinan could blame that second BMW dealer for accidentally erase your Dinan software and wrote it back with the factory original software... you know the usual BS... Dyno do not lie. if necessary, take two 2 different dyno facilities, then you contact Dinan first to tell them what happen. so when you go to your BMW dealer that install your Dinan, the Dinan Head Office already knew your problem... of course this is assuming your feeling is correct that the car still have the same horsepower... oh another thing to watch is your engine temperature gauge. Does it go up higher then usual ? because some other owner here report their car engine temperature goes up after they install the Dinan software on their car. This is normal since your turbo is working harder now. |
#54
from my personal view, a good engine tune should already make the engine work harder (more optimized to it's true potential) from lower rpm. because if you only have the engine produce much power over certain higher rpm, then the throttle response would not be linear, and the car would be jumpy. but I agree with you that the engine will endure much more stressed at higher rpm. so the temperature should go higher when you really push the car. Last edited by BMW Alpina; 11-14-2010 at 10:16 AM. |
#56
I wonder why it says its available for only 2010 and up? Maybe a typo? Last edited by AP24LA; 11-14-2010 at 12:12 PM. |
#57
I would question if the software was downloaded correctly. After my upgrade the difference was very noticeable at any RPM.
#58
Is your car running hot? Where is it sitting on the temp Gauge? Thanks
Car is not running hot, but outdoor temperature has been averaging 10 to 20 degrees cooler since I got the upgrade than it was prior.
#60
Update -
Days after doing the upgrade, a warning came up said, "Engine Malfunction, Reduced power." I immediately thought it was due to the tuning but it was actually the engine misfiring on two cylinders. Brought it in for service, informed my SA about the tuning so they could tune it again if they needed to. They did an oil change and an alignment (had both front tires replaced after 31k miles!) and the car drives like a dream. You get pinned to the seat when the car is accelerating and you are in the triple digits within seconds. Put the car in sport mode and it transforms into an S63 killer. I still haven't dared to put the car in Sport +. Local city driving has become somewhat of a annoyance because it is very jerky. I think the car could use a brake upgrade at this point, coming to a stop seems like a task now. Highway driving is where the car shines. The temperature has risen slightly as everyone mentioned, will try to get a picture, but it is not a major issue. It is in the 80's on average now and it does not seem to be affecting the car that much. I am not sure what the case will be in the Florida summertime when the temperatures can reach almost 100 degrees. Anything else comes up, I will let you know.
2012 BMW 650i
Mineral White Metallic - Ivory White Nappa - Driver Assistance Package - Full LED Headlights With 20" Style 356 Wheels - Instrument Panel With Leather Finish - Ceramic Controls - Head-Up Display - Luxury Seating Package - Premium Sound Package 12 650i - 03-14-13 09 750li - 05-23-12 06 750li - 10-21-09 03 745li - 10-18-08 00 540i - 12-14-05 Last edited by hammadurb; 11-25-2010 at 05:44 PM. Reason: Image resize |
#61
Dinan F01/F02
Hi there. newbie.
I read the thread and still not clear....did Dinan get the upgrade straight for the LI? Unfortunately, I was just told that the upgrade still is not approved for the LI X drive. Working with Dinan (trying to) and installer (Karl Troy at European - Charleston, SC) to see if it will work with X drive (and be certified/warranteed). If anyone can shed any light on this, thanks in advance. I did not see X drive referenced in the thread. kt2 |
#62
thanks, hopefully X will come soon. karl.
#64
I talked to Dinan in late October and was told they will definitely have it for XDrive, probably November or December; that sounded optimistic. I plan to call them again soon for a progress report.
#65
Thanks, Copasetic - you made my day!
The RDsport and ESS Tuning stuff does not look as strong as the Dinan possibility. Did you check those options out? I've left messages for Dan and Scott at Dinan and haven't heard anything back. They were looking for a download from an X drive and my tuner guy wanted me to drive 3 hours to Charleston, SC. He was going to do an upload from my ECU specs and off-load them to Dinan for review. Maybe they already got a hold of a car. Please let me/us know if you hear anything and thanks, again! Karl |
#66
Let us know if you find out anything, also. |
#67
Hi - just to clarify - we're talking about 2 different engines, right? The 750LIX engine is an N63, which is different than yours, correct? So, the fact that they may have it ready for your e39 may not help on the N63 time line as I am told about their process. Hopefully, they told you they were going to be ready for ALL Xdrives in 2010!
thanks...karl |
#68
Yes, there is no similiarity between my e39 and the current 750 XDrives. My e39 Dinan conversion was done many years ago, before I owned the car.
When I spoke to Dinan in late October, they told me they would have the ECU for the F01 and F02 Xdrive cars in November or December 2010. November's about gone, so let's hope for December. |
#69
Copa - thanks for the clarification....I get it. So, are you getting a 2011 750 Xdrive? Sounds like it might be in the works? thanks for the Dinan update - let's hope it is soon.
they are running 20% off software. Do they do this all the time, or is it really special to see a discount? I assume the dealer will discount as well? regards....karl |
#70
At least I got mine done for 20% off. Read through the entire tread, you will find more info for this 20% off. Some got charged for labor, some didn't.
Tip: If you are planning on getting your 7 a software upgrade or upload from BMW, do it before doing your Dinan software since everytime you do a BMW software upgrade, it will overwrite your Dinan software. If you are close to your local Dinan authorized dealer, you should be OK, since Dinan will redo your software for free(don't know if the labor charge will be free or not). But if you are like me at least an hour drive, it's such pain in the a$$ to drive back and forth
The 20% off discount is till the end of the year. My total was $2599. There was a charge for $32 for some part. Luckily, my dealership is the authorized Dinan dealer so if they upgrade my software, they just tune the car again.
2012 BMW 650i
Mineral White Metallic - Ivory White Nappa - Driver Assistance Package - Full LED Headlights With 20" Style 356 Wheels - Instrument Panel With Leather Finish - Ceramic Controls - Head-Up Display - Luxury Seating Package - Premium Sound Package 12 650i - 03-14-13 09 750li - 05-23-12 06 750li - 10-21-09 03 745li - 10-18-08 00 540i - 12-14-05 |
#73
my friend has an s63 - we raced for a few blocks and it was pretty even...bmw jumped off the line faster but about even...mbz exhaust sounds amazing...
#74
I wonder if Dinan will have a tune for my 2011 740i. That will be great.
#75
Newbie
Hi! I'm new to the forum. Just had my 2010 750i installed with the Dinan stage 1 software upgrade. The dealer told me to have the oil changed every 5000 miles from now on instead of bmw's usual 15000. Anyone heard the same?
| Bookmarks |
| Forum Navigation | |||||||
Today's Posts Search | ||||||
| Thread Tools | |
| Display Modes | |
