E34 (1989 - 1995)
Old 09-24-2010, 11:15 PM
fltstone fltstone is offline
Mein Auto: 1993 525i
Stomp Test?
I'm still trying to work out the bugs in my newly acquired 525I. How do I get the codes to flash in the display? I have tried to stomp the gas pedal five times in five seconds and nothing happens. Is there a setting somewhere that I missed?
Old 09-29-2010, 10:37 AM
bimmer dot info bimmer dot info is offline
The Biggest P0st Whore!!
Mein Auto: 2008 MS3
Turn key to run and immediately stomp 5 times. Wait a sec and the codes will start to flash using the check engine light.
Does your check engine light work?
Old 09-29-2010, 11:25 AM
I tried this several times and check engine light just stays solid. Car seems to run fine no misses, just trying to see whats been stored in the past. Stomp test just isn't working.
Old 09-29-2010, 11:46 AM
Banned
Mein Auto: car
Er......maybe your car has NO codes stored? i.e. everything is ok? You're not going to get historical records out of your stomp test. You probably bought a good car. Of course, if you feel the urge to spend some good money, check out the thread on the 89 535 front suspensions, its important, you can always buy the full kit and keep it at home till there's some damage, or until the urge to do something to your car passes. (tongue firmly in cheek )
I'll send you a link privately with a to-do list you might want to check out for a regular short or long term maintenance regime. Cheers.
Old 09-29-2010, 12:56 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
The stomp test should still work even if there are no error codes stored. In fact, if there are no error codes stored, the stomp test should show a code of 1444.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 09-29-2010, 09:59 PM
My car has been female owned for the past few years. I'm pretty sure there are codes stored. I need to get the stomp test to work if for nothing else just the history.
Old 09-29-2010, 10:59 PM
Banned
Mein Auto: car
Well the stomp test is pretty standard. You must have read about it from more than 1 place by now. There are no special switches or techniques beyond what you've read. If it doesn't work on your car, either the mechanism for the test is faulty or your car did not come with this built in. In either case, the stomp test option is dead for you. Time for you to move on. Purchase a code reader with an obd1 port (good long term investment imo) or bring your car into the dealer or some shop that can check through this. You got the car cheap, there's obviously nothing important wrong with it you just want to look at the codes for peace of mind purposes, which means you wouldn't mind tipping the mech for a scan as well. Make sure they clear the codes once the scan has been done and you've noted any stored codes.
Old 09-29-2010, 11:04 PM
Radian's Avatar
Radian Radian is offline
Mein Auto: '91 535i 5-spd
Went to perform the stomp test the other day only to realize my CEL bulb is burnt out. Good grief...
I knew I had a few other bulbs out on that side of the display, and I have been putting off replacing them for some time now. Who knows how long that thing has been out of service. Guess it pays to keep an eye on the bulb checks once in awhile.
Good food, good people, good times.
Old 09-29-2010, 11:32 PM
wisbimmer20 wisbimmer20 is offline
Send a message via AIM to wisbimmer20
Mein Auto: 1998 BMW 328I
Where do the codes flash? Ive never understood the stomp test. It seems like bull****. LOL
Previous BMWs:
1995 BMW 530i
1995 BMW 525i
Old 09-29-2010, 11:56 PM
Radian's Avatar
Bull**** is you, not googling to find out how to do it.
That's it, I'm coming north as soon as the Rib gets some powder. Pray I don't bring a dunce-cap with me when I show up on your doorstep.
I've needed an excuse to get back over to Pope's to get a new skateboard...er Rip-stik...er whatever the F?%* is in style these days
Old 09-30-2010, 12:07 AM
Radian's Avatar
wait a sec...I'll be the one wearing the dunce-cap for not checking my bulbs..ever.ROFL
Old 10-04-2010, 07:44 PM
es1758 es1758 is offline
Mein Auto: e36 525i
I cant get my CEL light to come on bulb is good tested the back of the board no voltage any ideas. it should be on when you turn the key correct
Old 10-05-2010, 09:33 PM
omarphi215 omarphi215 is offline
Mein Auto: 1991 525i Auto
What's up guys.. I had te same issue with the stomp test. It is supposed to display the dash lights correct? The green yellow and red, right?
Also the codes (1422,etc) where should I see these numbers?
Im a nooby, I have a bentley manual and the orig owners manual but I'm still asking the question. Maybe im missin something. Any help would be great. Thanks
