Fill up my tank => puddle of gas on floor!!!
Hey guys: ideas please before I rip the whole tank out.
I have noticed a light gas smell after long drives, but no wet patches on floor or tank bottom. I fill up (feeling rich!) on Friday, and the guy really fills the tank several clicks past the first pump click (I know, but was too late). There is a splash and gas, about 1/8 gal. I guess, falls very fast to floor. Looks like from front upper of tank. Any ideas? Thanks...
2002 540ia MSport Euro Factory fitted goodies: Titanium Silver, Blk interior/headliner MSport option 337, body, seats, s.wheel, shadowline, trim MSport op. 705, st II suspension MSport op. 204, 3.15 dif/ high stall tq converter Premium Sound with DSP + Sub Type 66 wheels 245f 265b |
If by "floor" you mean the interior of the car, that is bizarre and probably dangerous. Bill
'00 540iA/Sport, Anthracite/Black - Euro Delivery in Spring 2000 '06 Honda S2000, Black/Black (my go-kart) - GONE '03 Z4 3.0 6-speed/Sport, Sterling Gray/Black - GONE '71 2002 Green/Black - GONE |
ok, sorry Bill.
On the concrete gas station floor. The spill ran down the tank to ground. If there was a overfill from filling process, would it not end up at gas station attedants feet? ie right side, rather than left? Thanks for advice!
It is possible that the overflow pipe/tube isn't extending through the wheel liner and is then causing the fuel to run along the bottom of the car before it finally hits the ground. Get under the car and look.
Bill
Remove your rear seat bottom and insulation then take a look to see if the area of the sending unit is wet. If so, possibly a bad gasket. |
Had this problem with my track car. The side-to-side vent tube was not properly seated and had to be fixed. It's not a pressurized line, so not immediate harm/danger, but should be inspected anyway. The way to check it is to remove your rear seat bottom, pull back the carpet and sound deadening material, and remove the round gas tank access panel.
Brian 03 540iT Sapphire Black (E39) - 01 M5 LeMans Blue (E39) - 02 330Cic Orient Blue (E46) - 08 F800ST For Sale: *** Parting out entire 2003 E39 M5 *** - TONS OF PARTS AVAILABLE
I had the same problem. Car had a faint smell of gas and would drip fuel onto the ground after a full fill up. Realigned the sending unit gasket and the problem went away. As BMWtech said, it is quite easy to check.
bump any ne info on this??
It's possible the top of the connecting hose to the tank behind the wheel well liner has a split in it, or one of the clamps is loose.
Maybe the fuel ran down the liner toward the rear of the car. If your really want to know you will need to pull the wheel and liner, put the wheel back on, go to the gas station and fill'er up.
2000 540/6 Slightly tweeked...everywhere |
Ever wonder why 5 series electrical issues are common and complicated.. Spend time here and you will understand why. http://www.bmw-planet.com/diagrams/r...9new/index.htm
- Does spilled gasoline go into the charcoal canister (1)
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can't fill the gas tank all the way up | kcoetzee | E90/E91/E92/E93 (2006 - 2013) | 7 | 07-04-2006 04:59 PM |
| AndyM please read post below on gas tank and advise | 01silber | E36/7 Z3 (1996-2002) and E85 Z4 (2003-2008) | 0 | 11-10-2002 10:23 PM |
| Found little pin in my Gas tank...WHAT? | 330Guy | 3 Series / 4 Series | 5 | 05-24-2002 08:20 PM |
| my gas tank door doesn't close!!! | punkman79 | 3 Series / 4 Series | 4 | 05-05-2002 05:21 AM |
| Got 480 miles on a tank of gas! | alee | General BMW | 18 | 12-27-2001 01:51 PM |
