Old 04-22-2013, 10:30 PM
Punisher9113 Punisher9113 is offline
Mein Auto: 2003 BMW 525i M54 Manual
I have this same issue with my car only that when it gets to an inch from closed whether manual close or automatic. It stops and starts to open it again.
Sent from my XT907
Old 04-23-2013, 07:04 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
sounds like the point where it stops and starts again is what the computer is regestering as "home" postion. You may just need to "reboot" the switching.
What I might suggest is to find that "home position", then proceed to manually crank the moonroof all the way closed. Then try using the switch to open and close and see if that
brings yoiur mooroof all the way closed.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 04-23-2013, 03:32 PM
retiredat44 retiredat44 is offline
retiredat44
Mein Auto: BMW
mine is working fie as far as I know but it is hard to stop it at the exact point of where it is closed and does not start going up... is there some special way of pressing the button so it is auto and you don't have to let go at a certain point .. so it doesn't go beyond that point..
BMW 2001 530i (E39)
No longer own a BMW, sold it.
(Family cars):
2014.5 Toyota Camry Hybrid
Disabled Veteran:
Old 04-24-2013, 08:31 PM
retiredat44
Mein Auto: BMW
my sunroof also does not completely close before it starts going up, and will check to see if my toolkit has the hand crank so I can reset it..
2001 530i
BMW 2001 530i (E39)
(Family cars):
Disabled Veteran:
Old 04-25-2013, 01:14 PM
retiredat44
Mein Auto: BMW
Lightbulb
I found out I wasn't pushiung the button correctly... I tried agin, and found the best way to do it... my fumble fingers were the problem..
BMW 2001 530i (E39)
(Family cars):
Disabled Veteran:
Old 05-11-2013, 10:31 PM
rguanlao540i rguanlao540i is offline
Mein Auto: 540I-6
i have the same problem...when i close the sunroof it stops about an inch. it dosent bounce back, the motor struggles and just stops. i can push the button again to close position and it grinds. also, when i open the sunroof, it does not open fully..needs another quarter to be fully open.
i have attempted to reset the motor in the tilt and close position several times. it has not done anything. im currently trying to remove the sunroof off with the rear portion slightly in the roof....i have no idea how im going to access the 6 screws???
i believe there is something on the tracks preventing full movement of the sunroof. i have clean and sprayed grease on the track...oh and holding the deflector down while closing.
any thoughts from you pros?
i replaced my entire sunroof cartridge last year-i hope not to do it again. thanks!
Old 07-02-2013, 11:36 AM
Teemo Panda's Avatar
Teemo Panda Teemo Panda is offline
Bimmefest Plasti-Dip Guru
Mein Auto: E53, E46-M3, E70, F25-X3
Quick question. If the car still under CPO, will the CPO cover it? Since its a moving part?
Old 05-13-2014, 11:24 PM
bluebee's Avatar
bluebee bluebee is offline
Seek to understand,^Value
Another sunroof won't close thread today, for reference:
> E39 (1997 - 2003) > Sunroof not closing and bouncing back fixed
Originally Posted by 702ron View Post
Hello everyone. I had the common sunroof problem where it would almost close and bounce back, apparently hitting the deflector. Sorry if this has already been mentioned but I read several threads about the issue and most suggestions were to oil and lube it and to try and reset the sunroof. I tried all of these and got no results, so I just continued the "pushing the deflector down while it closed" method, which was a pain.
So I later decided to inspect all of the clips etc and realized there was an obvious design flaw. Apparently, over time the arms that pull the deflector down when the roof closes actually had bent the deflector just a tiny bit(less than 1/8") so that the arms no longer pull the deflector down enough. This is what was causing the sunroof to hit the deflector to bounce back.
The fix?? Just bend the ends of the deflector UP just a tiny bit. You can do this with your fingers. No tools required. Just bend it a little at a time until the roof no longer hits it when closing. That's it. 2 minute fix. Hope this helps someone.
Old 06-21-2014, 07:59 AM
bluebee's Avatar
Here's another sunroof issue today ...
> E39 (1997 - 2003) > Slide rail to sunroof. How do you get it out of the rail?
SunroofRepairComp.pdf
Originally Posted by kristiaa View Post
The main slide rail to sunroof on my 2000 528i, how do you get it out of the rail?
I have been trying to get this out with out luck if someone could let me know that would be greatly appreciated.
I tried place the pin in the old slide rail and the plastic broke apart, like all diy videos tell you to do. So now I have to replace the whole deal, which is fine if I knew how to do it?
I have been searching and searching and can not find anyone who is wondering this same problem.
Thanks ahead of time!
Allan
Old 08-08-2014, 01:11 PM
jermiester1's Avatar
jermiester1 jermiester1 is offline
'00 540i Sport
Mein Auto: 2000 540i
I had the same problem as several of you, the roof would hit the wind deflector when closing and stop. After reading this thread, I lubed the tracks and all the pivot points for the wind deflector. I figured the chances that this would solve the problem were slim, but amazingly it fixed it. I have opened and closed the window probably 20 times since and no problem.
18" Staggered M-Pars, Bilstein Sports, Dinan CAI, Dinan Free Flow Exhaust, Dinan Stage II engine and trans software, Front Aero Lip Spoiler.
Old 06-06-2015, 05:11 PM
EssoS EssoS is offline
Mein Auto: 2001 525i Touring
Whilst replacing broken plastic slider parts that stopped the sunroof from raising up I also tried this fix for the closing deflector bump.
Cleaned all the crud I could see and applied red lith grease to the tracks. I also followed 702ron suggestion above, leveraging the ends incrementally toward the center. So always bending, flexing the end up while pushing down at different points towards the center. Did for each side.
Fingers xed, working now with plenty of clearance.
Old 06-07-2015, 08:22 PM
AV8R4AA AV8R4AA is offline
Mein Auto: 2000 528it 2004 X5 4.4i
I sat and studied the operation of the sunroof.
Like others, mine didn't close all the way.
In the big picture above, look at the ramps on the 90 degree curved piece.
The ramps are what pull down on the deflector to allow the glass to slide
(Just barely) over the top of the deflector.
I tried toothpicks, wood chips, and the like.
I ended up fixing it permanently. I bought some JB weld epoxy.
On the ramp portion I built up with the epoxy the height of the ramp.
As in, I artificially made the ramp thicker.
This in turn caused the deflector to stow just a hair below the sliding glass.
I did it once and it has never worn off, chipped or failed to work.
Take a few operations from the outside to identify the moving parts.
You can also (with a pencil) depress the deflector down a little more and see that
the ramp trick will work.
I said pencil because I tried my finger and it smashed it.
I don't really like to make repairs with epoxy, but it worked so well I wanted to
share my repair.
I love my BMW 528it
Old 03-01-2016, 02:36 PM
HTownBMW525i HTownBMW525i is offline
Mein Auto: bmw
Originally Posted by DAPPA View Post
The problem I had was it wouldn't close all the way because it was hitting on the lid that folds down right before it closes. The rail, which has the wheels on a track to bring the lid down prior to glass completely closing, looked a little worn so I just added a clip to it. Works fine now!
I have the same problem the glass hit that lil lid thing rite before it closed and bounces back. But what do I mean by asded a clip? Plz help me.bro
Old 03-10-2017, 11:03 AM
Rookierepairman Rookierepairman is offline
Mein Auto: Ford F350
Originally Posted by MatWiz View Post
It's probably too much gap, but try to 'reset' it. Press the button and hold for 10-20 seconds (I forget how long exactly), until you hear an adjusting sound. Do it a few times. See it the gap closes.
mw
This worked great. Thank you!
