Old 09-28-2010, 03:38 PM
attila316 attila316 is offline
Mein Auto: None
Why BMW changed the rear rim size for staggered setup in F10?
Just curious. Does anyone know why BMW changed from 8.5 front and 9.5 rear (19" sports/m-sport E60) to 8.5 front and 9 rear (19" F10)?
I wonder if this has to do with handling or the dimensions of the larger F10?
Old 09-29-2010, 09:58 AM
shortcut3d shortcut3d is offline
Mein Auto: '11 535i F10
The front suspension changed dramatically and the rear was improved in the F10. Therefore, the engineers need to look at the wheel setup again for balanced handling. Typically, offset is used to counter over/under steer tendencies of the chassis. The F10 is corners much more level and has a lower roll axis than the E60. Also the new front suspension prevents the roll axis from having a front dive during cornering which leads to lift in the rear corners. Likely, that is the specific reason for the reduced stagger.
Current:
535i F10 - Dark Graphite / Oyster Black / Dark Wood - Premium Package, Premium Package 2, Convenience Package, Sport Package, Sport Auto
Previous:
6MT 335i E92 - Sapphire Black Metallic / Saddle Brown / Gray Poplar - ZPP, ZSP, Active Cruise, Navigation, CA, PDC, Heated Seats, HD Radio, iPod
Delivered: 11/03/07
Old 09-29-2010, 02:43 PM
helodrive helodrive is offline
Mein Auto: 2015 435i, Sport
When you have your tires rotated can they change the rears to the front and the front to the rears or just front left to right front etc.
Old 09-29-2010, 06:24 PM
goodchip's Avatar
goodchip goodchip is offline
Goodchip
Mein Auto: 2011 535i, Space Grey
BMW does not recommend rotating tires. Period.
Old 09-30-2010, 09:19 AM
Where did you find that out................that BMW does not recommend rotating tires. How about balance?
Old 09-30-2010, 10:11 AM
chrischeung chrischeung is offline
Mein Auto: 2015 550i / 2016 MB C300
The usual place - owner's manual.
2015 550i ED - M-Sport, Exec, Heated Seats, Rear Shades - 4/9/15
2016 Benz C300
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 09-30-2010, 10:23 AM
bklyn550 bklyn550 is offline
Mein Auto: 2011 550i sport
you cant rotate staggered wheels ....but new tires if they go bad....also if rear wheel drive the rears are going to wear pretty quick... as far as staggered all sports package cars have it...i think the quality of the rims is a bit better now as opposed to last two cars...tires seem a little bit more "regular"
Old 09-30-2010, 05:01 PM
Slaymaster's Avatar
Slaymaster Slaymaster is offline
Mein Auto: 2011 528i Sport Package
FYI The F10 528 sports package does not come with staggered but 18 all around with 245-45s all around.
BMWCCA Member #458528 www.bmwcca.org
"If Things Seem Under Control, You're Not Going Fast Enough"
Mario Andretti
