Old 09-29-2010, 01:09 PM
Jim Hughes Jim Hughes is offline
Mein Auto: 1998 740il
Check brake lights
The check break light flashing on when there is no problems. I have heard two things, one replace the tail light, the other is I have grounding problem. What is the thinking here? Thanks Jim Hughes
Old 10-02-2010, 02:57 PM
sealbeach740 sealbeach740 is offline
Mein Auto: 2000 740iS, 2003 540iS
Did you double check to make sure it isn't the middle brake light (on the lower part of the rear window)? Many of us forget to check the 3rd brake light.
Also, on the earlier e38s, there is a common problem of corrosion on the brake light sockets. Check yours & maybe use some fine sandpaper if you see corrosion.
2000 740iS. MKIV, 16x9, DDEs controlled by Euro fog light switch, reversed steptronic +/- pattern, paddle shifters, clear corners, Basslink, iPod video with stereo audio, TV tuner, gauge rings, ///M pedals, backup camera with 'on demand' switch, quad brake lights, Dinan engine & tranny software, windows/sunroof close via remote.
2003 540iS. MKIV, 16x9, PDC, CWP, TV tuner, backup camera with 'on demand' switch, paddle shifters, windows/sunroof close via remote, iPod video & audio.
HTML code is Off
