Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Classifieds > Cars - Private Party
Do you have a car for sale? Are you looking for a new BMW? Check here daily as well as searching on craigslist and eBay Motors
Old 10-01-2010, 01:42 AM
xphiledan xphiledan is offline
Mein Auto: R32
FS: 1985 BMW E28 535i (4-to-1 6-month build)
Due to an unfortunate turn of recent events, I'm forced to sell my E28. This car is a result of a 6-month build involving 4 different cars. It drives nice and tight, sounds incredible, and has real presence. E28s aren't common sights on the road, let alone a clean euro-bumpered one.
1985 BMW 535i
Schwarz on Anthracite/Cardinal
233k southern chassis
130k M30B34 engine (pulled from an automatic car)
1,000 miles driven since rebuild
The car was built by Guten Parts of Maplewood, a vintage BMW specialist shop:
http://www.r3vlimited.com/board/showthread.php?t=157693
Price is $12,500, a fraction of the total build cost.
I can be reached at (973) 722-0892 or at lin.daniel@gmail.com
Included with sale is a custom QQ license plate: "BMWE28"
Highlights
Recaro SRDs & Recaro height adjustable sliders
European Bumpers
M-Tech body kit (front, rear, fender trim)
Bilstein Sport Shocks / Spax Springs
OEM big brake kit (from 5 & 7 series)
3.73 Limited Slip Differential with RedLine
OEM French yellow low beams / smoked high beams
Euro Grills
Stainless Steel brake lines
German Check Panel
Valentine hardwired wiring
Rear premium Speakers
Redyed black/red leather interior
Redline transmission fluid
Nakamichi CD-400 with glove box aux Input
Custom VDO gauges (voltage, temp, oil pressure)
Powder Coated - Valve Cover, Intake Manifold, and Misc Engine Bay pieces
Sand blasted OEM exhaust manifolds
Front and rear strut tower braces
Upgraded front/rear sway bars
Nardi Steering wheel
New Parts:
New radiator
New fuel filter / rubber fuel lines
New belts
New hoses
High performance ignition wires
Custom cold air intake
Flow matched spark plugs
New cap / rotor
New fan clutch
New Magnaflow exhaust mid section
New Ireland Engineering stainless steel exhaust
AC Schnitzer exhaust tips
AC Schnitzer roundels
AC Schnizer oil cap
New timing chain guide / rail
New gaskets/seals engine (rear main, front crank, cam, all timing cover gaskets, oil filter housing)
New chain tensioner
Miller Mass Air Flow sensor & chip
New thermostat
Bored-out throttle body
New water pump
Tranmission: new input/output selector rod seals, pilot bearing/throwout bearing, fly wheel/pressure plate bolts
New clutch / pressure plate
New E36 M3 shifter & bushings
New ZHP shift knob
Rebuilt driveshaft
New Guibo
New CSB
New hoodliner, vent pads, powder coated latched
New Hood shocks
New O2 sensor
New French yellow fogs
George Graves interior light dimming module
New alpine front speakers
New Elemental design Amp
Custom smoked Guten Parts taillights
Antenna
New over-flow tank
Refinished BBS RA wheels & new tires (staggered)
Custom BMWPedals.com pedal set
New OE floor mats set
New leather shift / e-brake boots
535i, 5mt, bmw, e28, m30
