Old 01-27-2013, 09:06 AM
criskey criskey is offline
Mein Auto: bmw 525i
water damage
water accumulating in rear right passenger floorboard windsheild seal replaced andsunroof drain cleared,any information appreciated,thanks
Old 01-27-2013, 09:31 AM
Mikes00528i Mikes00528i is offline
Mein Auto: 2000 Electric Red 528i
Right rear passenger door vapor barrier needs to be resealed no doubt. Would make sense to do the left barrier too.
Old 01-27-2013, 10:52 AM
occhis occhis is offline
Mein Auto: 1998 528iA
+1 I resealed mine twice and it still leaks a little, but only during a driving rain when parked
Either you are part of the solution, or you are part of the problem.
Old 01-27-2013, 11:38 AM
Dunno but maybe it was resealed badly?
If that's the case, these threads may help:
- How the vapor barrier works (1) & the problem with front & rear door vapor barrier adhesives which allow rain water to wet the carpet (1) (2) (3) (4) (5) (6) (7) & what adhesives to buy (1) & what sizes for the adhesive beads (1)
Old 01-30-2013, 04:01 PM
Raeross Raeross is offline
Mein Auto: 2003 525i
Do you have a sunroof? It is highly likely that the drain lines for your sunroof are clogged. Now i am no expert but i know that There are ducts that channel water down from the sunroof area and, on a E39, thru the B pillar and then out the bottom of the car. These ducts frequently become blocked on my car and water mysteriously appears on the rear floorboard when there is heavy rain and sometimes when i go thru a high pressure car wash. Any technician who is aware of these aqua ducts can blow them out for you and there should be no more water damage. For awhile at least
Old 01-30-2013, 07:47 PM
Prob so, but leaking is minimal now - only in a very hard, driving rain - so I'm not getting into scraping all that sealant off and starting over again unless it gets to leaking more frequently.
