E34 (1989 - 1995)
Old 10-03-2010, 02:07 PM
iheartdelsols iheartdelsols is offline
Mein Auto: 1985 BMW 318I
1989 E34 525i (M20 Motor) - Idle Issues Hunting Idle
The Tachometer is pretty solid, no visible jump on the needle at all. Theres a weird spark sound coming from the rotor/cap when I unplug the #4 spark plug.
Heres everything I've tried so far:
- Valve Adjustment (3 Times) - Idles the same everytime
- Sprayed ICV Multiple Times - No Change in Idle
- Changed Spark Plugs twice - Found signs of Fuel on two
- Cleaned MAF or AFM
- Replaced Fuel Filter and Fuel Pump
- I have sprayed and visually inspected the vacuum line
I'm thinking its ignition related judging from the video, but I don't know many ignition tricks and I don't want to throw money at it that isn't necessary.
YOUTUBE LINK BELOW:
Any Tips would be great.
- Daniel
Old 10-03-2010, 03:35 PM
Banned
Mein Auto: car
1. Change the #4 spark plug.
2. Do you best to take a look at the #4 cylinder if you have a borescope. Do this with the spark plug still installed. Sometimes you spot the problem just by looking at it. I had a very similar problem as you did, turned out to be water in the No6 spark plug chamber.
Old 10-04-2010, 12:32 AM
BmwMan92's Avatar
BmwMan92 BmwMan92 is offline
I <3 my E34
Mein Auto: 1985 318i// 1988 325e
i think robertos got it or replace the coil since its only cyl 4
Brandon
http://www.facebook.com/brandon.m.fore
Originally Posted by v8bimmer View Post
I just dont see any other logical way around this problem.
Old 10-04-2010, 05:28 AM
Banned
Mein Auto: car
Its a 6 cylinder. Coil's not that expensive but its not that cheap and is hardly the problem. I knew someone who had a persistent cold start problem, which was ultimately traced to morning condensation seeping through his coil wires. Problem was fixed by changing it.
Dude, i had another listen to your video. I think your spark plugs may be loose. Tighten each one again, and once again, check to see if there's water in the spark plug tube. At may be lose if they were not properly tightened when you changed them.
Another tip...spray wd40 into the ends of the ignition leads and try to slosh it about abit before draining the fluid. Leave them hanging loose for 10 minutes before plugging them back in.
