Sponsored by The Tirerack. Moderated by Rudy@Tirerack.com
Old 12-27-2003, 03:43 PM
car_for_mom's Avatar
car_for_mom car_for_mom is offline
...worked on the railroad
Mein Auto: 2003 325i
checking tire pressure...a cautionary tale
Thanks to the Lord and Bimmerfest, I've gotten in the habit of checking Karl Bimmer's (2003 325i) tire pressure every two weeks.
I did so this AM (12/27/03), and I noticed a significant bulge in the wall of the right rear tire - I was immediately suspicious, and decided not to waste any time and get the tire looked at right away.
I went to the local Big O (I'd stopped in some months ago, inquiring about some rims, which meant larger tires). Mike patiently explained all about tires, rims and RWD - and I was impressed. Also, the store is very clean (important to women ) and efficient.
The other Mike came right out and looked at my tire, and told me it was a good thing that I'd brought the car in, because the inner wall was actually broken (probably hitting a curb, but I don't recall doing so), and the tire could easily blowout. I do a lot of highway driving - the last thing I need is a blowout at 70-80 miles on the 60/71/91/101/210/605/710/55/2/5/110/etc/etc/etc!
He showed me various 205 55 R16 tires, and explained about the Z, H and other ratings. Mike suggested a Fulda tire; a German-engineered, very good tire, Z rated (I'd never heard of Fulda - perhaps some of you have? ). It was in the middle of the price range (he didn't have any Continentals in stock, and I'm not that enthusiastic about Conti's, anyway.
Check your tire pressure regularly - it could save your life!
...in the freight yards!
Old 12-27-2003, 04:59 PM
The Other Tom The Other Tom is offline
Mein Auto: 2008 335i
Same thing happened to my daughter. Good thing she checked her pressure !! I took the car back to the tire dealer to get my money back on the "defective" tire. He explained to me about hitting a curb, etc and my daughter remembered she had hit a really bad pot hole, so bad she stopped the car and got out because she thought she had broken something. Bottom line, she wound up buying a new tire.
Re: Fulda tires. I don't know if it's a good idea to mix and match tires ?
Maybe you should check with someone from Tirerack ?
2017 i3 REx
2008 335i
2001 325i retired
2000 M Roadster Imola Red retired
1998 Z3 2.8L retired
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
ABSOLUTELY. A modern low profile tire can be under 20 psi before it "looks" low.
And low tire pressure is the main cause of blow outs.
Next thing is, do you know what the FIRST thing you do when you have a blow out? Most people don't.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
Old 12-27-2003, 06:31 PM
llando88 llando88 is offline
Mein Auto: Ram 2500 4x4
Well, what? What? WHAT?
(ms. Mom - I promise to check the air pressure in all the cars tomorrow morning, thanks for the reminder )
“Character is doing the right thing when nobody’s looking. There are too many people who think that the only thing that’s right is to get by, and the only thing that’s wrong is to get caught.”
- J.C. Watts Jr.
Old 12-28-2003, 05:41 AM
WILLIA///M's Avatar
WILLIA///M WILLIA///M is offline
95NU>*
Mein Auto: '04 Imola/Cinn M3
That's very true. Even with 17's you don't get a visual clue of low pressure until it's very low. I check every weekend.
I'm not a race car driver, but I play one on my TV.
Old 12-28-2003, 03:47 PM
I took the advice of several of you (I had been wondering, myself), and went and got a left rear Fulda tire - so both rear tires are the same. Mike at Big O did say that on a RWD car, the best tires should be on the back; I have about 8,000 miles left on the front ones, but I may replace them soon...
Old 12-29-2003, 01:14 AM
Pinecone's Avatar
M Mad
I am not a big fan of mixing different brand/model of tires on a car. Even front and rear. You have just put yourself into the role of tire test driver.
It may be fine, it may not. It may SEEM fine, until you have to make an emergency manuever. Just too many variables.
Consider this, on an airplane this last summer I met a Michelin tire engineer. This guy has a PhD and he works on ONLY slip angles of tires.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-29-2003, 07:07 AM
fkafka fkafka is offline
Mein Auto: '02 330xi
Put down the latte and newspaper?
Old 12-29-2003, 09:15 AM
The HACK's Avatar
The HACK The HACK is offline
Rest in peace, Coach
Mein Auto: '06 MZ4C, '09 WRX Wagon
Especially with the new run-flats.
Initially, the Z4's run-flats were WAY under-inflated from the factory. They were at 20-23 psi all around, but visually they look the same at 20 psi as they do at 36 psi.
And since ALL the tires were under-inflated, it never triggered the tire pressure monitor.
Old 12-29-2003, 05:10 PM
Pinecone's Avatar
M Mad
Awesome. That is a way to get another B/F tire fiasco.
Did you know that the RECOMMENDED pressure for the Ford Explorer was around 26 psi? Not very far to WAY to low for highway driving.
And for the wag, this is done BEFORE you even put down the latte and paper.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-30-2003, 09:37 AM
I don't know the right answer, but I'll guess 1) make sure you have a death grip on the wheel with both hands, 2) take your foot off the gas, 3) put on the e-blinker (without using your hands?), 4) bleed off speed without braking.
What's the right answer?
Old 12-30-2003, 03:56 PM
Pinecone's Avatar
M Mad
BLEEP, wrong.
A couple more guesses and I will let you in on the answer.
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 12-30-2003, 04:16 PM
BLEEP, wrong.
For front blow out:
1) maintain speed and determine if you can steer safely
For rear blow out:
1) Slow down and pull over normally 'cause you can't bloody tell you had a blow out until the steel cord in the tire starts whacking the body work (this actually happened to me in an Accord, I mean, it was a mile before I know the tire was gone
That's two guesses, ok so what's the answer?
- J.C. Watts Jr.
Old 12-30-2003, 04:50 PM
BLEEP, wrong.
Guesses:
A) Say "#@~!"
B) Wet your pants
C) Scream like a little girl
Any of these even close?
Old 12-30-2003, 07:10 PM
wrwicky wrwicky is offline
Send a message via Yahoo to wrwicky
Mein Auto: Max Von Zhipper
I've heard some rumors that B/F recommended 42 psi which rode too firm, so Ford asked them to go as low as they could B/F came back with 36 psi, this was determined to ride too much like a crudely suspended heavily laden truck still and Ford went with 26 which B/F objected to.
Also, I think over 50% of cars are cruising around under inflated. 20 psi+over 4000 lbs+interstate speed= NOT GOOD
2003 330i ZHP Mystic blue, Alcantara, Silver Cube
I'm already pulled over!
Old 12-31-2003, 02:22 AM
Pinecone's Avatar
M Mad
Answer:
http://www.bimmerfest.org/forums/sho...428#post621428
Terry Carraway
'95 Alpine M3 LTW
'02 Topaz M3
Old 01-05-2004, 12:31 PM
I listened to the "butt dyno"...
After I replaced the rear Continentals with the Fuldas - I had to admit that something just didn't feel quite right - the "butt dyno" (must be like Spidey's "Spider Sense" ) was tingling.
Now - I may be totally off my rocker, but when I would take a sharp turn, I'd hear a kind of 'clunk', and the DSC would be disengaged (light on).
This AM (1/5/2004) - I just decided to replace the front tires with the Fuldas - and I noticed a big difference (pauses for the "I told you so's!" ). I deliberately went through some curves in Carbon Canyon (checks to see if any Chino Hills/Brea Police or California Highway Patrolpersons are reading this ) at, let us say, a higher rate of acceleration than I normally do - and I didn't experience the DSC being disengaged.
You guys were right - Bimmerfest rocks, again!
Old 01-13-2004, 08:26 PM
The Roadstergal's Avatar
The Roadstergal The Roadstergal is offline
Any ride will do
Mein Auto: 2014 320i
When the DSC light flashes, it means it's kicking in - if the light is on steadily, it's off.
"This is a revolution, dammit! We're going to have to offend SOMEbody!"
Old 01-13-2004, 09:39 PM
I refer to it as the "Fun" light
Old 01-14-2004, 01:27 PM
LmtdSlip's Avatar
LmtdSlip LmtdSlip is offline
Do the interns get Glocks
Send a message via AIM to LmtdSlip
Mein Auto: 325iC
Probably due to different overall diameters from front to rear fooling the computer into thinking there was wheel slip when if fact there was none.
Glad everything worked out OK for you
Photobucket
Old 11-11-2005, 06:10 PM
John Danskin John Danskin is offline
Mein Auto: M Z3 Coupe
link to drive with a flat answer bad
this appears to be a bad link. it sends me somewhere called bmw2005 with popups and no ideas about how to drive with a flat.
Old 11-12-2005, 06:24 AM
RobertB RobertB is offline
Mein Auto: 06 530xi, 03 330Cic
The link used ".org" instead of ".com" in the domain name. The corrected link is below.
http://www.bimmerfest.com/forums/sho...428#post621428
